How to Change Needle and Seats in 100-6 Carbs?
hundredsixinsf
Can someone walk me through the removal and replacement of both needle and seats in the two carbs on my '59 100-6? I've never done this before. Can it be done without removing the entire carbs from the engine?
Can't walk to far these days. However, if you are referring to the float needle and seat here goes: Remove the carb bowl tops. You will see a small shinny pin holding the float lever assembly to the top.slide the pin out and remove the float.Using a properly sized socket unscrew the needle assy from the top. Keep track of the number of paper washers between the top and the assy. Using the same no of washers from your repair kit reinstall the assy and tighten throughly. Reinstall the float lever. Now turn the lid upside down insert a 5/16" rod between the hump in the float's lever and the bowl top blow through the fuel inlet no air should pass.Reverse the bowl top and you should have free air passage. Reinstall the top and you are good to go I think. /ubbthreads/images/graemlins/grin.gif---Keoke
Isn't there a little bent wire thingy that holds the needle? (maybe that was only on my "B") Bob
Not to my knowledge Bob. the needle is captured within the seat housing when it is installed.--Keoke
Yeah, I just checked my catalog and there is no such thing, must have been thinking about my Briggs and Straton--same size! Bob
