AUSMHLY
How to: Brighter gauge face with LED’s.
The following will address Negative ground and Positive ground.
This was done on my 1964 BJ8.
Here’s what I came up with to help illuminate our dash gauges better than the stock 2.2 watt filament bulb. This is just my solution, other views may vary, but who cares about them anyway. You’re reading my mine right now. I rock! (Disclaimer: I don’t really rock, others may chime in with why not to do this modification, or why I don’t rock. Most of all, please be careful).
First things first: If you have not already done so, put an inline fuse on the back of your dash light toggle switch. Before touching any of the wires, disconnect the power.
The stock filament bulb, a 2.2 watt, gives off a somewhat dim yellow glow, what’s called a warm light. There is only one bulb in the rear of each gauge to light up the dial face. A good portion of the light is blocked by what ever mechanism is in the gauge. And unlike newer cars where the face is illuminated from behind, the light in our gauges has to shine through the 1/8 inch gap between the cylinder circumference and the gauge face. This is the case for the oil/water, speedometer and tachometer gauges. The fuel gauge requires the light to reflect off the back face, then forward to the front face, not through a 1/8 inch gap on the edge of the dial.
I tried an 8 watt filament bulb. It was brighter, but still mostly only the top most portion of the face. The problem was the bulb got too hot. And we don’t need any more heat in the drivers foot well, do we.
The best solution I found (again, other views may very, blah, blah, blah) was to use an LED. For this project, I tried many different types of LED’s. It needed to be as bright as possible (cool white) and illuminate as much sideways and forward as possible, like filament bulbs do. (LED’s like to focus their beams forward, which doesn’t help with our situation).
Negative ground:
If you have converted your car to a negative ground, this will be a plug and play.
Replace all (8) original E10 filament screw bulbs with the E10 Superstar led from https://autolumination.com/otherleds.htm
Replacing the bulbs behind the green directionals, will allow you to actually see them flash in the daylight. No, I’m not kidding. However a slight amount of current will bleed thru to the other indicator when in use. It’s a very small amount and it may not bother you. You can fix that by installing a small 100 ohm load equalizer across the circuit to absorb the energy. That will make the indicator led’s stop lighting when they are not supposed to. See this link: https://autolumination.com/equalizers.htm
Once you have replaced all (8) bulbs with led’s and patted yourself on the back for surviving all the contortions you just put your body though, turn on the dash lights and marvel at how talented you are. Maybe while your calling all your friends and neighbors over to look at how your gauges light up, you noticed that the speedometer and tachometer dials don’t light up at the bottom as bright as the top does. Some will say, I can live with that or maybe you’re like me and think I got a little more contorting left in me. Plus I get to spend a little more Healey mad money on (2) more E10 Superstar led’s I’ll need.
Remove the speedometer and tachometer gauges. Place the gauge face down. You should now be looking at the back, with the black plastic bulb socket at 6 o’clock. Drill a hole the same size as the other bulb holes as close as you can to the left of the black plastic bulb socket. (Either remove the face from the gauges first or use a powerful vacuum to help keep the metal shavings from entering the gauge as you drill. I highly recommend taking the time to remove the face. If you do, spray the inside of both barrels gloss white. It will help brighten up the light). Make sure to leave enough room between the two holes for the bulb holders to clip in. (SEE PHOTO). Buy two more E10 sockets and splice the center wire into the red with white stripe wire that goes to the stock socket. You should be able to buy these identical sockets from British Victoria or British Car Specialists. (Hard to find the E10 socket, most supply the bayonet style). Now put it all back together and let your friends/family who are now wearing their sunglasses as they stare at your gauges, pat you on your back. For you too now rock!
Positive Ground:
Led’s require a negative ground to work. To get around that in your positive ground car, you will need to isolate each socket. Here’s what I did. Others may have a simpler or safer way of doing it.
You can not use the stock E10 bulb holders.
I tried the wedge type and the bayonet type. The wedge type did not lock the bulb in as does a bayonet. We don’t want the bulb falling out of the socket into the gauge after we take a hit from that pack of cigarettes in the road, do we.
You will need (12) bayonet barrel socket holders.
Here is a link to where I purchased some.
https://www.egauges.com/vdo_indA.asp?PN=ATM-2357
You’ll need (12) BA9s bayonet HID white high power led bulbs.
https://www.v-leds.com/Shop/Control/Product/fp/vpid/4481035/vpcsid/0/SFV/32481
Once you have the sockets, you'll need to isolate them. I found heat-shrink tubing works better than electrical tape. Your local hardware store or Radio Shack may stock the size you need. The size should just slide over the socket barrel. Insert the bulb into the socket and heat-shrink from the top edge of the bulb, to the bottom of the barrel socket holder. The more area you cover, the less chance for an accidental grounding error. (SEE PHOTO).
You’re off to the hardware store again. Grab the tachometer gauge and the bayonet socket holder that now has the LED bulb heat-shrink-ed in place. You’ll need (6) rubber grommets. Grommet thickness may vary, so try a few to find the one that fits the hole and makes a snug fit with the socket. I found the right size at Orchard Supply Hardware. (4) Grommets will fit into the top and the new bottom hole of the tachometer and speedometer gauges. (2) will fit into the directional housing cylinders. (SEE PHOTO).
The fuel and oil/water gauge have a metal tube with four slits in it that the socket wedges into. Widen the opening end of the tube a little, so as to lessen the chance of cutting or ripping the shrink wrap, which is acting as the isolator. (Take care not to let any metal part of the bulb (the very end of the bulb) or socket touch any metal part of your car.) Or you’ll be testing your new inline fuse. Once the sockets are pushed firmly in the gauges, they will stay in place. Try removing one. Care should be taken when removing or installing. I would recommend using your power cut off switch in the boot when ever you need to get to these bulbs, or work on anything electrical. Oh, and don’t forget to look both ways before crossing the street and wash your hands before dinner.
Now... the final step. How to actually wire up the negative ground sockets into your positive ground car. Carefully.....ok then, my work here is done. Good luck!
First, cut the power off. All bayonet sockets will be using two wires, even though some of the original sockets had only one wire. All gauges will be wired the same way.
The center wire from the bayonet socket will be spliced into the center wire from the original E10 socket. The outer grounding wire from the bayonet socket can be attached to any metal of the car. A convenient place is the bolts on the back of any gauge that has a black wire grounded to it. You can either cut the original E10 sockets out and replace with the bayonet sockets or leave the original E10 sockets there and splice into their wires. Don’t forget to isolate the original sockets if left hanging under the dash.
Congratulations!
Seems you made it this far without nodding off.
This project may take a little time, but the reward of clearly seeing your dials at night will be worth it. Plus now in the daylight you will be able to see the directional…. that has been blinking for the last 5 miles. And you thought those other drivers were just waving at the coolness that is you, because you have an awesome car.
Happy Motoring!
Roger
Negative ground:
Positive Ground:
Congratulations!
Happy Motoring!
Roger
Hi Guest!
