twas_brillig
Looks like we're going to have to have a 1275 rebuilt this summer and I'd appreciate suggestions for improvements.
Cylinder head was worn out and we had it done previously (including valve seats for unleaded gas) but the free advice I'd received years ago that the block was fine was apparently worth what I paid for as the shop it's in advised that it smokes quite a bit.
We'll stay pretty much stock and will be using existing carbs/header, but I was thinking to:
- spend a bit of time and match the ports/gasket/intake (just because)
- ensure it's got the double row timing chain
- get the crankshaft main caps machined and add straps
- have components balanced
- higher capacity oil pump?
- better piston rings? (decades ago, I had a BMW 2002 engine rebuilt and the shop recommended non-BMW rings)
- if it doesn't have a rear crankshaft oil seal conversion (we have a Datsun 5 speed behind it so may have already done that upgrade; age is going up and memory is going the other way)
- talk to the machine shop about 'lapping' the oil pressure relief 'bullet' into the block (anyone else have thoughts on this?)
- pertronix ignition
- retain the spin-on oil filter
- head gasket upgrade? I'm thinking that the stock one will be just fine, but advice appreciated
- upgraded bolts/studs/etc? Again, I'm thinking that stock will be find, but advice appreciated
- keep stock starter (replace with gear reduction when it fails)
- any recommendations for 'better' valve cover and oil sump gaskets?
Comments on the above? What else would be worthwhile?
Thanks, Doug
Thanks, Doug
