sparkydave
I checked on the valve lash this evening, partly because it sounded like I had at least a couple of loose ones, and because it had been a couple thousand since I last checked. The book says 0.010", but most were more like 0.013", and two were at 0.016". I got them tightened up, but without changing anything else, suddenly the engine seems to be running more evenly, and the slow idle was now up around 1500 RPM when it was 800 before. I'm not griping about the smooth running though, it would be bucking occasionally at speed, and once I backed the idle back down, it just sounds better overall. Now I wouldn't have guessed that a few thousands of an inch would have changed valve timing that drastically, but did it? I know you don't want them too tight or they won't seal when hot.
