I was just out checking stuff and noticed the carb damping oil is low. I just filled those a few weeks ago after going through the carbs. Seems like a lot of leakage to me. What say you folks?
Should only be up to the top of the piston tube, too (inner "lip" looking down the bore from above). Not above it. Some could be getting past the needle but not likely. Check and top up maybe once a month with steady driving, normally.
