How not to start a freshly rebuilt 100/6 engine
5
57_BN4
This is a workshop that appears to have rebuilt a paying customer's engine. I hope he got oil pressure up before this little episode.
Fast forward to 3:00 where the cranking begins.
BoyRacer
In my opinion, I don't think oil pressure is a problem here. The assembly lube on the bearing journals and camshaft lobes are more than enough protection in the time that the engine takes to build oil pressure. I know this must sound like blasphemy, but cranking the engine over and over in order to build oil pressure has the consequence of scraping off a lot of the assembly lube that is more beneficial than any oil.
As I see it, the real problem with this scenario, IF this is a fresh engine, is that the engine RPMs are not high enough to get the lifters (tappets) spinning in their bores in order to properly break-in the cam. Proper break-in procedure would be to immediately get the engine to AT LEAST 1500 RPM and holding it there for 20 minutes or more. If this is the extent of these clowns breading-in this engine....that cam and lifters are toast. I suspect the situation will manifest itself after a week or two of driving the car.
57_BN4
Yes. What got me was just how sloppy the whole operation is and how dumb somebody is to put this on YT under the name of the machine shop. If he is prepared to start an engine by stamping two wires together rather than take a few minutes to wire a solenoid in then it doesn't say much about the quality of what has gone into the engine assembly.
BigGreen
Never mind the cooling ;-)
At least they got a spare block ....
BigGreen
How long? No idea how many minutes but ...
There is no cooling liquid (tubes are open at the end). There is no airstream (no fan). The sump is surrounded by the support.
Normaly with some coolingfluid in, but without motion, it will start to boil somewhere in the head
Without any fluid at all, things will go much faster. In the wrong direction that is
drambuie
Well, you get what you pay for right? We all have our particular budgets to work with when restoring our cars. Personally, I would chose a shop that tests newly rebuilt engines on a dyno, such as the SF-902 dyno the Healey Werks uses, check out there web site. Someday if needed, that's where I plan to have my motor done and upgraded. With my bad back my motor pulling days are over!
Healey Nut
Yep its true , you get what you pay for and it certainly looks like a pair of rednecks at "redneck rebuilds" . I would'nt want to be the customer of that engine .
rcflyer
If that engine has a new cam & lifters...whoops, they surely won't last long. The guys at APT said if you do this the cam may only be good for 1,000 miles or so. No warranty on the cam if it is not broke in correctly. When I started my newly rebuilt MGA 1600 engine it was a little scary, but I brought her right up to 2600 RPM and ran her 25 minutes per instructions for the Cam mfg. Kept an eye on oil pressure and temp...which were fine all the time. Then let cool a little, changed the oil & filter, put in VR-1 20w-50 and so far so good. I would not have known to do this break in if I had not have asked. Have about 1200 miles on it now. Oil change coming up this week., Lee
andrea
I see also part of the 12 Videos of this mechanic, with others type of engines, all was started with this method, and same support
bob hughes
Just gone over the 500 mile mark on my rebuilt engine. It has been bored out to the max and all parts balanced, I rebuilt the engine myself using graphogen rebuild compound on all moving parts. The crank was turned by hand as each bearing and piston etc. was put in place to ensure that there was no binding.
All start up work was carried out with the engine in the car, coolant in and plugs out and fuel pump electrics disconnected, the engine was turned over on the starter for around 60 seconds to build up the pressure in the system and get the oil flowing around. Then I connected up the pump, installed the plugs and slackened the dizzy clamp, turned over the engine again rotating the dizzy until she started and tuned her up from there. First oil change will happen in the next few days, I will also be adding in the antifreeze at the same time.
All looking good and we have not yet gone over 2500 revs. though I have been told I can now open it up a bit by a Healey specialist - the main point is not to stress the engine.
:cheers:
57_BN4
Hi Bob,
I guess we have different philosophies on running in a newly rebuilt engine, here is a pic of my Longbridge lump about an hour after first startup. Since then I have had the sump off to change the cam out and found just a small amount of black fuzz on the sump plug magnet so I think she is in pretty good health despite this treatment. Andy.
BoyRacer
So Bob,
You told us how you rebuilt your engine but........What did you do to break in the cam and lifters in your fresh engine? I ask since that was the point of my first post criticizing those clowns for starting a "freshly rebuilt engine".
drambuie
I remember as a kid I would watch my neighbor build gas dragsters from the frame up using 4130 moly tubing and building all his racing motors as well, in fact Don Garlits and Don Prudomme "the snake" where his racing buddies before they became famous in the NHRA drag racing world. Anyway, one of the things that was common among theses guys was using STP on all the internal motor components when assembling there motors. I used to watch my friend open up a can of STP and spread it on all the rod bearings, cams,lifters, cylinder walls....everything! In fact we built my 427/435HP Tri power corvette motor the same way. After careful checking of clearances, torquing and resembling of the motor we would slowly turn the motor by hand. Then install the motor for our run in. Which consisted of a short period of running listening to the internals with a stethoscope. Then it was road tested at slower speeds at 50mph for about 20 minutes, allowed to cool and repeat the run in process for the first 500 miles. Change the oil make tappet adjustments,head bolt torque settings and go! At least that was the proceedure for street motors. Really basic stuff! Some people I knew would run there motors at full tilt and did not believe in a gradual break in period Which always made me shudder!
Somewhat off topic, but aircraft piston engines absolutely must be broken-in at full power, full rich, at low (as possible) altitudes and for extended times (an hour or more). This is so you get max BMEP and the rings will seat; if you don't do it this way you're all but guaranteed to have low compression (and will likely void the rebuilder's warranty). Some resort to putting Bon Ami in the cylinder in an attempt to break the glaze. If you have CHTs (cylinder head temperature gauges) you will see the temps rise to scary levels for a few minutes, then come down quickly as the rings seat. They're run full rich to purposely wash oil off the cylinder walls to assist "final machining."
This is a religious topic, but my dad who was an auto shop instructor and factory rep for Ford says "break them in how you're going to drive them." Others say "break them in slow, get a slow engine." One thing that does make sense to me is if you baby an engine for too long you'll get a ridge at the top of ring travel, then when you finally punch it the rings may hit the ridge and possibly be damaged. Modern engines are so precisely machined that usually no specific break-in is required.
bob hughes
So Bob,
The cam was a Racer Brown and was in the engine when I bought the car. I discussed the state of it with my local Healey man and it was decided that it did not need replacing. The valves were in good order and just needed lapping in as the head had been modified to unleaded a couple of years back and rebuilt with new rockers and shaft, so all these parts were put back in using the graphogen.
:cheers:
Patrick67BJ8
Hi Bob,
Here are pics of our clubs Engine Test Stand that our local club members can borrow to use to break-in their engine before it goes into the car. We have a dummy transmission to support the engine and exhaust pipes w/ mufflers. The engines owner must use their radiator, battery, etc. Also a pic of the "Engine Oil Primer" that a club member made to get oil through the engine before spinning and starting it up. It uses a home made oil tank and is hooked up to a small air-compressor and the engine is primed until oil is coming out of the rocker shaft and going down to the lifters. After starting the engine we run it up to a little over 2k rpm and adjust the timing, carbs, etc.
57_BN4
Hi Patrick,
I'm making a similar rig this week with the addition of a water brake dyno on the back for load testing. The pic above is when I was using my old chassis for an engine stand but due to lack of space it got cut up and scrapped. This one looks a bit neater than the rusty old chassis. Andy.
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
J Spitfire No start after fiddling with dash Triumph 2
AHSebring How do I create "Contact" to "Start Conversation" in my About Tab? FORUM Navigation Questions 1
O Wedge 79 TR7 no start Triumph 5
J MGB 1966 MGB won't start MG 1
K TR2/3/3A Sluggish cranking on start up? Triumph 5
L T-Series Hard to start MG 11
mctriumph General TR NEVER start a car with stale gas Triumph 0
K TR2/3/3A Timing chain rattle on start up? Triumph 2
KVH General Tech Initial Start Up After Rebuild Triumph 23
B Healey Won't Start - No Spark Austin Healey 38
T TR6 Perfectly tuned TR6 wont start when hot. Triumph 11
G Pre-War how to start a 55 mgtf. MG 3
KVH TR4/4A Hard Start When Engine Hot Triumph 20
K TR4/4A TR4 no start Triumph 26
M Spridget wont start Spridgets 50
D TR2/3/3A Getting difficult to start. Triumph 6
K TR2/3/3A Motor knocking at start up? Triumph 11
Q TR2/3/3A Where to start?! Triumph 13
Got_All_4 Wedge An issue with trying to start my TR7 Triumph 12
dougie Bruce McLaren's start in an Austin Healey Austin Healey 0
K TR2/3/3A Hard start questions.... Triumph 4
pairof75's General TR Circulate fluids without engine start Triumph 10
S TR2/3/3A Will Not Start Triumph 52
R TR2/3/3A Re-start after total restoration Triumph 22
S General MG 77 MG no start MG 31
B Cold Start Problems BN7 Austin Healey 21
S TR2/3/3A I have this miss where the car will start and kinda idle Triumph 23
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T 100-6 start up issues Austin Healey 6
tr6nitjulius General TR AutoX & Rallye Start TRIUMPHest 2019 Triumph 0
K TR2/3/3A Mystery stall and no start? Triumph 7
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
tr6nitjulius New Official Start Great Race 6/22/19 Video Other Cars 0
tr6nitjulius Great Race 2019 Official Start 6/22/19 pics Other Cars 2
I General TR TR6 won’t start, no lights Triumph 12
RAC68 Healey Will Not Start Austin Healey 5
S TR2/3/3A try start it with the key and it blows the fuse Triumph 7
J TR6 Wont Start Triumph 10
Sarastro TR4/4A Another milestone: first engine start Triumph 8
HighAltitudeTR3 TR2/3/3A Doesn’t want to start up again after a ride... Triumph 24
Gerry M TR6 TR6 Won't Start Just Clicks Triumph 17
G Failure on Initial Engine Start After Rebuild Austin Healey 176
M Cold start problems Austin Healey 33
D Lily Engine first start Austin Healey 9
KVH General TR TR4A Engine Won't Start Triumph 34
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
K TR4/4A Success on the TR 4A No Start.... Triumph 0
K TR4/4A 4A No Start? Triumph 14
