TR2/3/3A How much oil should the steering box have in it?
karls59tr
Bronze
Is the correct level supposed to be at the fill plug?.....not that the oil will actually stay in or anything.:smile-new:
TR3driver
Great Pumpkin - R.I.P
Yup.
fill%20steering%20box.jpg~original
TuffTR250
Since I had my TR3 I have not removed the rubber seal in the steering column. I did remove the plug on top of the steering box and there was pretty yuking looking oil in it. I know I need to do something with it, but have not gotten around to it. So today, based on this forum thread, I decided I should at least pull the rubber plug. UGH, it looks like someone filled it with thick wheel bearing grease. Questions:
1)Any idea how I can get that grease out?
2) What's a good way to drain the steering gear box without removing it from the car and also without removing the front cowl?
3) And should I buy the special "Penrite" oil that Moss sells for steering boxes, or is there some other oil that is just as good?
Sorry for all the string of questions!
Regards,
TR3driver
Grease might be tough. Working some kind of solvent (eg kerosene) into it to liquefy it might work, but that might further damage the seal. However, chances are the seal is already toast (hence the grease).
Usually you can just loosen the compression nut on the face of the steering box and the oil will slowly run out.
The only advantage of the Penrite IMO is that it is very thick (sometimes called semi-liquid grease) and slow to leak out. I use Valvoline full synthetic gear oil, which IMO is a much better lubricant and lowers steering effort. But, your box & seal need to be in top condition, or it will leak out quickly. (Mine still leaks a little, but not much.)
As a side comment, I struggled for many years with a worn-out steering box. I believed others when they told me "They all steer like that", and more or less just lived with adding oil to the steering box every time I added oil to the crankcase. Then I finally bit the bullet and rebuilt the box on my (former) TR3A. My overriding impression was "Why didn't I do this years ago!?". The difference was simply remarkable, and now I know that they don't "all steer like that".
On the 3A with the split steering column, I did manage to get the box out without removing the front apron. Still not sure if that was actually easier or not, but I got it done. (Had to take the engine mounts loose and jack the engine over to one side, plus remove the horn and maybe the upper crossmember, not sure about that offhand.)
TuffTR250
Thanks Randall! I'm thinking that I could use some small engine cleaning brushes I got from Eastwood to get most of the grease out of the steering column. I would then like to flush the column and the steering box with kerosene. Is that a good idea? If I did that, how would I get all the old kerosene and gunk out of the steering box? Seems as though just removing the compression nut would still leave quite a bit of dirty fluid at the bottom of the steering box.
Regards,
TR3driver
I don't have a good answer for that. You could remove the plate on the front and get a little more gunk out, but that it still going to leave some amount inside, and it may be tough to get it all back together properly.
Really the best approach, IMO, is to remove the box for cleaning, and replace the bushing, seal and peg. Since you don't want to do that, perhaps a better approach for now would be to do several changes with gear oil, at least dilute the gunk.
N How much oil should an engine use on break in Triumph 20
richie TR4/4A How much oil is normal.. Triumph 6
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
J New engines burning oil, Too much fuel? Triumph 14
V How much extra engine oil with oil cooler??? Spridgets 5
6 too much oil pressure??? Triumph 25
RJS Oil and Filter Change [how much oil?] Triumph 2
DarwinT How much oil in the tranny? Spridgets 6
T How much dashpot oil leakage is normal Triumph 14
B How much oil when you have an oil cooler? Triumph 4
S How Much Oil Triumph 4
mylillooker Oil, ...how much? What kind? Spridgets 2
Andy Blackley High Oil Pressure: Too much of a good thing? Triumph 11
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
DrEntropy MGB Differential with too much lash MG 5
HealeyRick Why 100Ms Cost So Much Austin Healey 14
Rut How much does a 1275 weigh? Spridgets 8
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
Healey Nut sooooooooo , how much will it go for ?? Austin Healey 24
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
GTP1960 TR2/3/3A How much is to much fretting? Triumph 10
NutmegCT So many cars! So much has changed! Other Cars 10
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
HealeyRick How Much is that Healey in the Window? Austin Healey 7
TomMull Air Compressors, how much is too much? Restoration & Tools 7
glemon How much paint? Restoration & Tools 8
Trevor Jessie Waaaay too much body roll Spridgets 14
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
S How much grease for the drive [prop] shaft plunger Austin Healey 3
J How much movement in slave cylinder plunger . Austin Healey 2
T TR2/3/3A How much vibration in a Triumph 4 cylinder engine? Triumph 12
J Clutch fork free play on BJ8 How Much? Austin Healey 13
F Too much procrastination[maybe long winded] Austin Healey 9
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
drooartz How much fender beading for Bugeye? Spridgets 17
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
Jim_Gruber How much spare fabric in needed to cover panels / dash on a BE. Spridgets 10
B How Much Pedal? Spridgets 2
J How much to buy an engine block and head? MG 3
johnrip how much gas for winter storage Triumph 17
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
nevets How much brake fluid to fill the system? Austin Healey 3
W 2012 Daytona 200 - missed it by that much British Motorbikes 6
