HOW MUCH MOVEMENT IN SLAVE CYLINDER PLUNGER HAVING TROUBLE CHANGING GEARS AND WOULD LIKE TO SEE IF I AM GETTING ENOUGH TRAVEL. I AM GETTING 5/8" MOVEMENT AT PLUNGER, thanks
It could be a few things first see if your loosing fluid then it might be the slave or the mc then if it was never changed it could be the hose they deteriorate over time if that doesn't work you might have no choice to take out the tranny and put in a new clutch disk
