How much dashpot oil leakage is normal
tdskip
My rear carb dashpot seems to be leaking oil. How often do guys top up your dashpots?
FYI - I'm using 20w50 motor oil
TR4
I rebuilt my carbs 3 years ago and have not had to add oil yet. I have only driven about 2000 miles though on the rebuild.
TR3driver
Great Pumpkin - R.I.P
I consider any leakage at all to be abnormal; but I do top them up at every major service. The excess oil runs down the shaft and lubricates it.
There's an O-ring inside the piston that fails and causes the leak. To replace it, you basically remove the needle and it's carrier (unscrew the mixture adjustment and remove the retaining screw on the side), then use a pencil or similar object through the hole to drive the mixture adjustment screw and it's retaining clip out the top of the shaft. The process is covered in detail in one of the carb articles at Buckeye Triumphs
NickMorgan
I tend to fill mine up about two or three times a year. I suspect that they are a little worn.
poolboy
I had one that tended to go down. I emptied both dampers and went back with Bars Rear Main Seal Repair. Seems to be the same viscosity as 30 or 40w oil.
It must have swollen the o-ring enough to stop the leak.
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Uh oh...[/QUOTE]
Ahhhh, Tom???
What the heck does that mean??
mrv8q
Tom, BTDT. Follow Randall's advice and check out the Buckeye Triumph /Nelson Reidel 3 part carb-rebuild PDF. It's so good, I had my printout bound at Kinko's. Use Randall's tip of using the pencil to push the needle/o-ring assembly out. This is also a good time for the ZS carb tool you have in your toolbox.....
prb51
That's pretty heavy oil for dashpots ain't it..20/50? I use a 30 weight in the summer and auto tranny fluid in the winter.
Oh no, another oil thread....
R
RonMacPherson
Moss used to have the orings for this leakage available. Probably still do.. I found similar size at my well stocked auto parts house, in their oring supply drawer... Might also check a plumbing supply store or well stocked hardware store.
skucera
The O-ring comes in the carb rebuild kit, which is how I got a new one. Even with my new O-ring, I still top up my oil about once a month. On my old Midget 1500, I used to top its damper oil up about twice a year. Victoria British has the O-ring as a separate part; that's where I got my rebuild kit, new metering needle, and my adjusting screw.
Scott
TR3driver
tdskip said:
Yeah, you guys are (of course and as usual) right. I'll do it properly.
It's easy and quick; but if it's keeping you off the road I'd just live with the leak for awhile. It's not like it gets any harder because the carbs are mounted or have been driven.
The seal sweller is an interesting idea ... never thought of that.
Not sure I understand the comment about 30 weight vs 20W50. Remember that 20W50 acts like 20 weight @ -10C and 50 weight @ 100C. Since the carbs are much cooler than 100C (boiling point of water), the effective weight will be somewhere between those two numbers. If we assume the change is linear, and the carbs are around 40C, the effective weight of 20W50 comes out almost exactly 30.
That said, I found that straight 20 weight seemed to work best for me in my TR3A. Haven't repeated the experiment with the Stag yet, though.
toysrrus
Hi There tdskip,
I have never had the need to top up the dash pots.
I bought from Moss Motors their "Damper Oil" which is specially designed for SUs & Strombergs. What the mix is ???
I bought it just to have it & have virtually never used it.
Its not cheap but you`ll never have to worry about the mixture.
Russ
V MGB Folding convertible vs stow away. What years? How much difference? MG 2
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
S BJ-8 SU Fuel Pump Clicks Much Faster Than Before Austin Healey 9
DrEntropy MGB Differential with too much lash MG 5
HealeyRick Why 100Ms Cost So Much Austin Healey 14
Rut How much does a 1275 weigh? Spridgets 8
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
Healey Nut sooooooooo , how much will it go for ?? Austin Healey 24
AHS TR2/3/3A Residual brake pressure valve - how much front wheel drag? Triumph 18
GTP1960 TR2/3/3A How much is to much fretting? Triumph 10
NutmegCT So many cars! So much has changed! Other Cars 10
D TR4/4A How much play acceptable for input shaft bushing? Triumph 2
HealeyRick How Much is that Healey in the Window? Austin Healey 7
TomMull Air Compressors, how much is too much? Restoration & Tools 7
glemon How much paint? Restoration & Tools 8
Trevor Jessie Waaaay too much body roll Spridgets 14
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
K TR2/3/3A How much oil should the steering box have in it? Triumph 6
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
Lukens TR2/3/3A How much travel at the clutch slave? Triumph 12
S How much grease for the drive [prop] shaft plunger Austin Healey 3
J How much movement in slave cylinder plunger . Austin Healey 2
T TR2/3/3A How much vibration in a Triumph 4 cylinder engine? Triumph 12
J Clutch fork free play on BJ8 How Much? Austin Healey 13
F Too much procrastination[maybe long winded] Austin Healey 9
H TR4/4A Triumph 250-K by Pete Brock--anybody recall how much Brock advertised it for? Triumph 1
E How much should i pay for a complete 100/4 engine ? Austin Healey 4
richie TR4/4A How much oil is normal.. Triumph 6
drooartz How much fender beading for Bugeye? Spridgets 17
M Broken off dip stick plastic tube, stuck oil pan, and I think too much... Spridgets 10
M Cleaning up under the hood - just how much needs to be painted? Spridgets 2
Jim_Gruber How much spare fabric in needed to cover panels / dash on a BE. Spridgets 10
J New engines burning oil, Too much fuel? Triumph 14
B How Much Pedal? Spridgets 2
J How much to buy an engine block and head? MG 3
johnrip how much gas for winter storage Triumph 17
V TR2/3/3A TR3A Brake Pedal - Too Much Travel Triumph 6
AN5Sprite T-Series Considering an MGTF, how much $$$ MG 20
nevets How much brake fluid to fill the system? Austin Healey 3
W 2012 Daytona 200 - missed it by that much British Motorbikes 6
rkep01 How much do you think this will sell for? Spridgets 33
F T-Series How much to pay? Photos of 1955 MG TF 1500 MG 17
F How much of a premium? BJ8 vs. BJ7? Austin Healey 16
CZ_Dave One is too much, a hundred isn't enough MG 4
R Getting Much Closer Triumph 73
Darrell_Walker Leaks, some fixed, some maybe not so much Triumph 7
F Am i Worrying to much??? Spridgets 9
V How much extra engine oil with oil cooler??? Spridgets 5
Got_All_4 TR2/3/3A TR3 leans too much to the right Triumph 10
