TR2/3/3A How many miles to seat piston rings?
mastaphixa
Bronze
Recently rebuilt engine. I'm at 500 miles and am re torquing the head. The engine runs very well with no noticeable oil consumption. I do get several drops of oil out of the road vent tube over night after a 25 mile drive. How long does it typically take to seat the rings? I'm running Valvoline VR1 20w50. Steve Baker
poolboy
I did a series of compression test. Do one now at 500 miles; then do another at 1000....continue on at intervals of your choice if you want.
CJD
It depends on the type rings and cylinder finish.
Chrome rings in a cast iron cylinder will take at least 1000 miles of street driving.
Standard cast iron rings on a relatively rough honed cylinder (you can easily see and feel the hone marks on the cylinder wall) take at least 500 miles.
molly rings in a fine honed cylinder (cylinder walls look like a mirror) will seat as soon as you do the bedding procedure below.
To bed new rings, take the car out where you have room to alter speed without getting rear ended. With the car in 3rd gear, accelerate under full throttle from about 20 to about 60 mph. Then take your foot off the throttle and allow it to coast back to 20 mph, still in 3rd gear. Repeat about 10 times and you have bedded the rings. The accel loads them against the cylinder to mate them...the coasting provides vacuum to draw oil up and cool them.
Finally, if you are using parts supplied from the big 3...you have cast iron rings, so 500 miles is probably your answer. Oil usage should drop to nearly nothing by that time.
TomMull
I don't think a couple of drops from the vent pipe is unusual although it might get better after the rings wear in. Might not too.
Tom
Spitty
You might notice the inside of the tailpipe is whiteish until rings seat. Then back to normal black/brown when seated. I drive new rebuilt a bit more spirited for the first few hundred miles
K Spitfire '78 cuts out after many miles of driving Triumph 8
Rob_P How many miles do you get to a tank of gas... MG 3
K TR2/3/3A Rebuilt TR3 Engine....how many miles before ... Triumph 5
S How many miles did you drive your AH in 2006? Austin Healey 30
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
linuxcoupe General MG Lamp to LED Conversion - How many ballasts to use MG 5
ahealey1004 For Sale MGB OD transmission, many parts in Phoenix,AZ MG Classifieds 4
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
M Fat Feet hitting too many pedals Austin Healey 23
AUSMHLY BJ8 Manifold, how many brass nuts? Austin Healey 2
Y MGB First of probably many questions - driveshaft transplanting: MG 3
A Spitfire Here's Our latest Newsletter.. Scroll Down -Many Tech Sessions Images Triumph 0
NutmegCT So many cars! So much has changed! Other Cars 10
Tr3aguy General TR So many parts Triumph 7
AngliaGT Many Minis Spotted 5
Sarastro TR4/4A TR4 saga continues: why does Craigslist attract so many flakes? Triumph 16
T How many hours to reassemble a BE? Spridgets 16
Rut MGB Too many cars MG 31
M How Many McLaren owners are here? Other Cars 6
S This is why I spend so many nights in the garage... Spridgets 7
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
HealeyRick How Many Big Healey Guys are Spridget Guys? Austin Healey 23
J E brake help forgo many Big Healey owners Austin Healey 8
B How many of you have or had an Austin A40 Somerset Other British Cars 16
luke44 TR2/3/3A TR3 Door Panel Screws - Location - How Many and Where? Triumph 10
MikeAH100M How Many BN2 Overdrive Relays?? Austin Healey 2
J How many people retain their original generator? Spridgets 16
Frank C. How many Healeys are still on the road? Austin Healey 10
B TR6 Removal of TR6 crankshaft end bolt! MANY THANKS! Triumph 3
af3683 SU Carbs - How many flats? Triumph 3
JamesWilson How Many Left? Spotted 6
HerronScott How many left in the UK Triumph 6
03RedSRT4 Our Jensen Healey restore project, many questions. Other British Cars 35
JPSmit Too many cars too little time Other Cars 4
N craigslist post - many MG parts MG 1
T I'm an idiot / Hazards of too many projects / help Triumph 9
W How many carpet clips... Spridgets 8
richberman How many takers for collapsible steering? Austin Healey 12
S MGB-GT Too many MGB GTs.......? MG 3
drambuie How many more core's can a stock radiator handle Austin Healey 8
G 1500 Registry [how many here?] Spridgets 17
B How many ways can you say UGLY!!!! Spridgets 25
T TR6 How many alloy locating dowels on TR6 trans Triumph 6
