TR2/3/3A How long do leaf springs last?
GTP1960
After removing the rear leaf springs, shocks & linkage.
noting the deterioration of the shackled rubber bushings, buffers & silentbloc I am wondering if I should just replace the springs as well, because everything else in the rear suspension is worn out?
the springs appear fine. The old ride was rough & stiff (but what else is new).
no knocks, squeaks or tilts to speak of.
so my question is: is their a rule of thumb on when to replace the leaf springs?
thanks for reading & any advice appreciated.
GP
Geo Hahn
I replaced mine when one broke - 53 years & about 180,000 miles. But I think the answer as to how long they last will be 'it depends'.
TR3driver
Great Pumpkin - R.I.P
What he said.
When TS39781LO came to me back in 1984 (so only 26 years or so old), both rear springs were discovered to be broken shortly afterwards (but not at the same time). When I was assembling TS13571L in 2008, I assembled two spring packs from the best leaves from 4 different springs. Looked fine, but one of them suffered multiple breakages a few months ago.
Also, of the pair of original springs I was given from someone else's restoration, one matched the book while the other was significantly weak.
Of course if you do replace them, the question becomes what to replace them with. I've heard many stories of springs from Moss being too stiff; and the ones I got from TRF are way, way too stiff. Testing confirmed that they have almost twice the spring rate given in the manual!
At some point, I plan to contact a local spring shop and see if they can build to the specs in the book. But for the meantime, I've assembled a pair that seem to match fairly well, and the ride is much improved. Still not like a modern car, but IMO not that harsh "lumber wagon" ride that TR3s are famous for either.
PatGalvin
During my suspension resto, I took my stock springs apart, cleaned up all the leaves, greased them (red moly wheel bearing grease), and reassembled. The leaf clips broke, so I rewelded those so they would stay closed. The springs give a great ride, but the car bottoms out occasionally on dips in the road, especially with a passenger on board. I have the "heavy duty" lever shocks as rebuilt by Apple Hydraulics (stock shocks, but modified somehow).
Just a data point for others to consider.
Pat
CJD
I keep them until they have obviously failed. "Obviously failed" for me is when a leaf breaks or the car sits crooked or on the bump stops.
Pat, I bet your car bottoms occasionally because the good grease you used is much better at lubricating the leaves as they slide on each other. They should stiffen a bit as the grease ages.
GTP1960
GTP1960
What he said.
This is from the "for what it's worth dept."
I got a note from Albert Runyan at TRF, stating they had some issues with their leaf springs & are looking for a new supplier.
Also the current springs in their catalog is a "universal" spring, meaning driver side & passenger side are the same.
regarding custom made springs:
I asked for a quote from Eatons in Detroit and got this reply:
(they didn't have the template or specs for TR3)
"If you can not find them get back with me for if we had one of your old springs we may be able to make them for you.
Thank You
Mike
Phone 1-313-963-3839
Fax 1-313-963-7047
www.eatonsprings.com
mike@eatonsprings.com "
looking at some of their other prices for resto-cars, I assume the cost would be pretty high.
thanks for the insights.
I think I'll try and refurb mine and get another 20 yrs out of them ( That should be enough for me)
TR3driver
When was that? I traded emails with Albert about a month ago, and he was still waiting on answers from their then-current supplier (who was apparently Heritage-approved). As I told Albert, I'm willing to be the guinea-pig if they do find a new supplier.
On top of that, they are TR4 springs. Same spring rate (according to the workshop manual), but higher ride height.
But neither of those things bother me; the left/right difference was just a spacer that I can easily add if I want. And another spacer would bring the ride height down.
Yeah, that's the impression I got too. But the ancestor company of the local spring shop once added some leaves to my motorhome springs for me, and the price was pretty reasonable. I'm hoping they won't be too high now.
GTP1960
GTP1960
"When was that? I traded emails with Albert about a month ago, and he was still waiting on answers from their current supplier (who was apparently Heritage-approved). As I told Albert, I'm willing to be the guinea-pig if they do find a new supplier."
just today: here is his email:
" albert runyan
Guy-Thanks for the order.
I'm having some issues right now with the leaf springs. I'm checking some other sources and if all goes well, we should have some ready to ship you in a couple of weeks. Sorry for the delay.
Albert
TRF"
TR3driver
Thanks, Guy. I guess he never did get a good answer from the (former) supplier. Let me know how it goes, please.
B TR6 Crankshaft long seal surface Triumph 5
jfarris Message too long error FORUM Navigation Questions 8
L My 1951 Triumph long ago British Motorbikes 0
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
W Generator and Starter Long Bolts Spridgets 0
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Zitch Engine Oil Leak After Long Drive Austin Healey 19
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
R The long road home Spridgets 1
Y MGB An odd (and probable long-shot) request... MG 5
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
T BT7 throttle relay levers short and long Austin Healey 2
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
R TR2/3/3A Restoring a 54 TR-2 Long Door Triumph 10
boxofparts TR2/3/3A My long term 30 yr project Triumph 5
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
roscoe Leakdown test [long read] Austin Healey 11
aero3113 Healey Shop on Long Island Austin Healey 9
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
D MGB Painted rubber bumpers. How long will they hold up? MG 1
T C42 BJ8 generator long screw needed Austin Healey 2
PeterK General TR Time for a long ride Triumph 3
D After a long break.... Spridgets 6
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
L TR6 need help on long dead TR6 Triumph 16
Sarastro Morris Minor in Long Beach, CA Spotted 1
D TR4/4A extra long oil filter attachment stud Triumph 9
D TR4/4A flywheel bolts maybe too long Triumph 15
Sarastro Red TR3 in Long Beach, CA Spotted 0
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Marla TR4/4A Take the long way home Triumph 11
K TR2/3/3A How long should an SU damper top up last? Triumph 22
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
TomMull TR2/3/3A Long Door anyone Triumph 16
B TR2/3/3A TR3A VS TR4 Long Tube inlet manifold Triumph 8
KVH TR4/4A Long Speedometer Cable for OD Transmission Triumph 10
