How Hard Is Racing On A Car?
I have only done Solo 1, no wheel to wheel racing, but I have found that a car prepared to "fast road" as opposed to full race tune can be reasonably inexpensive to run, if you don't drive like an idiot.
By the last comment I am referring to watching your rev counter, using the clutch when you shift, not doing burnouts when you take off, or otherwise abusing the car by showing off.
My TR4a has modest power output, stock crank and pistons, so I limited myself to 5500rpm. The car was fairly easy on brakes and tyres, (mostly because it did not go very fast!), at least 10 events (10 days at the track, about 150kms or 100 miles each on average) on a set of brake pads, and at least that long or longer on a set of tyres.
I did "slick" the gearbox through with the clutch partly engaged when changing from 3rd to 4th, after the lever gets to neutral you can let the clutch pedal up and complete the shift at the same time.
I did use the overdrive but had no problems, even occasionally using it to bridge the gap between 2nd and 3rd, which is tough because there is more torque in the lower gears. I used the clutch when doing this, or there would be too much slip. In seven years off and on I had no failures, and only a couple of minor problems like a loose coil.
All out racing with a real race car is different, though, my comments refer only to a "street prepared" car.
Simon.
Yes, I agree that starting in an underpowered car means that to get anywhere you need to learn car control and make the best of handling. You either stay slow (and frustrated) or you become a smooth driver - all that sliding and darting around may look good to spectators, but it ain't the fastest way around - and you are ready for a car with more power. Drive with your mind, not your gonads. The Corvette newbies are like a golfer trying to just hit that [censored] ball as hard as they possibly can without much thought about where it may end up....
I have beaten quite a few V8 powered cars (Mustangs etc.) because they never learned to drive around corners or brake to the point of lock-up.
Passing - sometimes means thinking 2 or 3 corners ahead to plan which side you want to be on when you make your move to pass a competitor that is about the same speed as you. If you do it right, he runs out of room and you stay on the line. If you do it wrong, you are the guy backing off, and/or ending up on a slow line.
Racing lines - something they usually don't teach you in driver training is that the optimum line is speed dependent. I recall running a race with a bunch of new driving school graduates. At the first corner they dutifully all pulled to the outside of the track, taking the line they would need to take when negotiating that corner at full racing speed. Only thing was that we had just come off a standing start (not too many organisations do that any more) and were going through at lower than normal racing speed. As they pulled to the outside I just drove by them on the inside and was still within my cornering envelope at the speed I ended up doing through the corner.
Hap - you made me think about what is original on my MGA race car. The frame and centre body shell, with dash is pretty much it. Oh yeah, and the passenger side door (the driver side was ripped off against the Armco when I exitted backward at speed due to mechanical snafu)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]Re: How Hard Is Racing On A Car? [/QUOTE]
as hard as <u>it</u> will let you be......
