Hello to all those who are now on the streets.....what symptoms does one see with a faulty or dead voltage regulator?I suspect it in causing a short circuit and causing the fuse to melt,which allows the car to run just fine,sans the little things like overdrive,fuel and temp guages and,oh yes,turn signals......all of these are fed through the same circuit.The vehicle can be running with no apparent problem,the steering goes lock-to-lock without causing the fuse failure.Attempts to drive more than a mile without fuse failure have proved nil.........
