G
'Splain to me again how I can reduce the oil flow in my auxillary oil line to the head. Something about inserting a friction pin somewhere to choke it down.....
kodanja said:Please explain to me why not?
70herald Because the cost of rebuilding the bottom of the engine is much higher than replacing the rocker shaft. The bottom needs the oil far more. The more oil on the top said:<span style="color: #990000">To answer your question Bill: as is known by many,
old Tinster knows next to nothing about auto mechanics.
But from my very limited experience having watched TRbill and 2Wrench
struggle with the bottom ends of their engines and poor Paul Rego
on pins and needles just waiting for his new cam to blow to pieces,
I'd have to reckon the cost of rebuilding the bottom of the engine
is much higher than replacing the rocker shaft if it runs dry of oil.
The bottom end needs the oil far more than the rocker assembly.
The more oil on the top, the more oil blown out of the engine into the
PCV / air filter or where ever the outlet on the head goes.
I popped the valve cover off my engine and looked inside. A tiny drop of oil
was coming out from tiny holes in the rocker arms. Everything appeared well
lubricated so I'm guessing there was more than enough oil.
Plus I stayed at a Holliday Inn and called Yisrael for his opinion!!
d :thumbsup:</span>
Funny, that's where mine is too.Trick6 said:So it is in the storage cabinet in a plastic bag.
