TR3driver
Great Pumpkin - R.I.P
Which all sounds normal for your commission number (assuming by "sideskirts" you mean what most people call either sidescreens or side curtains). There is an equally odd fastener known as a Dzus button that holds the side curtains to those brackets. It in turn takes a special T-shaped square-tipped wrench that is also used for the hood "locks" and spare tire "locks", and possibly for the trunk latches (since it appears you have an earlier trunk lid).CUPWALKER said:The TR3A I have the joy of restoring has outside locking door handles and a rather odd looking bracket for the sideskirts and also front disc brakes
Correct on the Triumph being more or less the first quantity, series-produced car with disc brakes (I believe Jensen may have had them earlier, not to mention a few Crosleys and Chrysler Imperials, but not in anywhere near the quantity of cars built). However, the disc brakes fitted to TR3s were always Girling. (Triumph had tested Girling, Lockheed and even Dunlop disc brakes on the Le Mans team cars in, I think, 1955.)bmurphy7369 said:Just some trivia, the TR3 is considered to be the first mass-production car fitted with disc brakes (Lockheed being the first version fitted, 1955 and on?), that is if I remember my history correctly.
Never white, to my knowledge. Whether the rear flasher lamp lenses were amber or red depended on the market for which the car was built, with typical "North American Dollar Area" (as my Lucas Master Catalogue describes it) specification being red rear flasher lenses.bmurphy7369 said:Also, at some point the two rear center lights changed from red to white or to amber I think, corrections welcome here of course....
I'll disagree, although perhaps only over terminology. 'Tenax' normally refers to the studs with the round ball on the end, and the fastener with fingers that grip the ball until the knob is lifted. A TR3A should have those only on the top edge of the windshield. All the other fastening points for convertible top and tonneau cover should use "Lift the Dot" fasteners, which are simpler (and much less expensive). LTD studs are more of a rounded cone shape, with only a rounded indentation for the fastener to grip.bmurphy7369 said:and I believe the Tenex studs on the door as well,
It's my belief that Moss is mistaken. The factory documentation is somewhat unclear on the point, but I believe US-spec TR3s started getting the inboard turn signals earlier than the rest of the world did, at about TS15601 instead of the TS18913 that Moss gives. The TRA judging standards also give the earlier change point. The rear apron pressing remained the same (with the big hole in the middle), but the chrome license light covered the hole, and there were plinths added to carry the turn signals. (Later cars have the plinths pressed into the apron.)<div class="ubbcode-block"><div class="ubbcode-header">Quote:]If I replace it with the combo brake and license plate lamp assembly, is the center brake light functional? ie three brake lights- My new screw connector wiring harness doesn't run a brake wire to the center--[/QUOTE]You would have to run an additional wire to the center brake light to make it work. Not too hard, but an extra step.<div class="ubbcode-block"><div class="ubbcode-header">Quote:]How important is all this--will I be penalized for incorrect fittings-[/QUOTE]Yes, even if you never enter a show! Sooner or later, someone will be telling you it's "wrong" ... even if it isn't.emmett1010 said:The rear apron has the rear flashers mounted separatly, with the later styled License lamp assembly.
According to Moss, my car should have the combo, brake and license lamp assembly.
