Hi Guest! If you appreciate British Car Forum and our 25 years of supporting British car enthusiasts with technical and anicdotal information, collected from our thousands of great members, please support us with a low-cost subscription. You can become a supporting member for less than the dues of most car clubs. There are some perks with a member upgrade!
Lift up the carpet around the shifter, and you'll see a rubber plug/cover on the left side of the tunnel. Remove that and you'll see a fill plug on the transmission. Remove that and you can see the fluid level. Should be level with the threads.
No dumb questions here. There is a rubber cover on the left side of the tunnel below the shifter. Remove that and you will see a large plug nut on the transmission. Unscrew that and have a look. Good luck screwing the nut back in without making a mess. You also fill from this location. If you can work from underneath it is a little easier.
Dumb questions are OK--I've asked my share--but I'll repeat my standard mantra: This kind of thing is in any shop manual, so it sounds like you don't have one. You really should get one. Without it, sooner or later you'll do something you'll regret. You can get a Haynes manual for about $15, and it's pretty good.
Are you checking the condition, level or both? You can't check condition except by draining it out the bottom plug. Then you'll have to open the top plug through the tranny hump access hole anyway. .. 11/16" IIRC. An extension helps.
