TR6 How do I remove the rheostat from dash of TR6?
2wrench
I suspect faulty rheostat and want to investigate. How does the rheostat knob on the dash of a TR6 come off
without damage?
Other knobs have push pins requiring pulling. I don't
want to damage the unit and I do not see a push pin or
the like?
Do I just grab with a pair of pliers and tug/pull?
roofman
Mine has a square shaft with a ball detent. Wiggle it off carefully by pulling straight off.
Harry_Ward
If you can get to the back end of the rheostat switch and you have a multimeter? With the <span style="color: #FF0000">ignition power off </span> connect the + lead from the meter on one terminal of the rheostat and the - lead of the meter on the other terminal of the rheostat. Set the multimeter in ohms mode x1, turn the rheostat switch on and the needle or digital readout should move or read something depending on where full speed ahead is the multimeter will go up and down the scale as you turn the knob from fully on to off. At off you should have no reading. That's if you can get to it or the wires coming from it.
Brosky
It doesn't make any difference if the switch works or not, the lights are always dim. One of the TR6 curses.
Now, I'm just kidding so we don't get into a big debate about that topic again!
Well, your switch may be malfunctioning, but I'm really not kidding about the dim part.....
Definition of an oxymoron: dimmer switch on a TR6
tomshobby
I agree with all of the above. The only thing with mine was that with the sloped sides I could not get hold of it to pull and it was really on tight.
I did find that I could get to some of the dash wiring much better with the glove box out.
And as far as the dim lights go, I always liked them that way because they did not distract while driving at night and from the current and previous threads I seem to be in the minority on that. I actually keep my TR6 dash lights dimmed some.
DougF
One of the features of the TR6 from the factory was a faulty rheostat. Mine have only worked as on/off switches.
Brosky
Re: How do I remove the rheostat from dash of TR
Tom, be honest now! You keep your lamps dimmed because that's the only setting that actually works! Dim or dimmer are the two options available.
T
Tinster
The DPO Pedro of my car had the rheo ripped out
and put in a cigarette lighter. That was one reason
I had functional dash lights.
If you are not trying for 100% showroom, you can
purchase very nice looking, flat black, on-off toggle
low profile button switches. Mine has a tiny blue
light at the button bottom when my dash lights are lit.
In my opinion, the rheo is not worth the money to
replace it. You will always have it craked on full
and still have dim dash lights. Go for the $7.00 switch.
d
Brosky
Dale, one of these days, when it gets warm again and I'm done getting side tracked with carb and distributor projects, I'm going to take the dash apart, disassemble and clean all of my gauges. I'll replace the old bulbs with the higher wattage bulbs and then there will be light in the instruments. I saw a TR6 in one of the summer events that had the higher wattage bulbs installed in rebuilt gauges and it looked really cool at night.
T
Tinster
Paul,
If you saw higher watt bulbs and brighter gauges,
you also probably saw gauges that had been altered
with mirror finish interiors and some of the back
lighting baffles cut away.
Think about back lighting along the ceilings in
restaurants. Brighter bulbs will have minimal
increase to room brightness, unless the ceiling and
back-lit areas are coated with a highly reflective
material.
Remember last summer we did the real world test of
unaltered gauges. 2.2 vrs 5 watt bilbs in unaltered
gauges? No apparent difference in lighting.
By design, the Smith gauges were never intended to be
bright shining stars.
d
tr6_easyrider
My solution for the infamous dimmer switch. The hole is still there, only not cut out.
I wish I had used Dales,highly reflective material, idea
for the gauges. I did paint all the surface inside the gauges white, and that did help. They are defintely much brighter.
Brosky
Man, does that interior look like a familiar sight from a few months ago. Clutch time?
tr6_easyrider
No, no clutch. I still have the cover off from the short I had with the insulation shorting the overdrive switch. Still in the restoration phase. She has not been on the street yet. As a matter of fact, she hasn't been out of the garage yet.
Joe
T
Tinster
Here is my solution to the rheo in my 69TR
Local rainforest teak dash.
Brosky
Dale, that's a thing of beauty, buddy!
T
Tinster
Thanks Paul!
I ain't a half bad designer, am I?
right and left turn signal lights
and the dim high beam, brake failure and
ignition all moved onto the dash.
Toggles for wipers and washer fluid.
Red switch is my emergency driving lights
that feed directly off the battery, if need be.
Flush toggle between the 4 small gauges turns
on the lights inside the gauges themselves.
Now, if I only had an operational car!!
d
Brosky
Soon, my friend, very soon.
Just keep the faith. In the meantime, I've got to get outta here. 5AM comes too quickly these days, so hasta lavista for tonight.
Paul
roofman
Verification question. If you disconnect reostat wires and tie them together, you will have full dash lites on all the time with no other concequences, yes or no?
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
CARSINC How to remove factory contact cement? Spridgets 9
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
drooartz Bugeye jack points to remove rear axle Spridgets 18
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
newmexTR3 TR2/3/3A How to remove thrust washer from lower wishbone & trunion Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
drooartz Hose from water pump to head, remove water pump? Spridgets 12
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
tahoe healey Nano Magic scratch remove Austin Healey 2
F I can’t remove Wire wheels from new hubs - help Austin Healey 43
Basil 7 Ways to remove stripped screws Restoration & Tools 2
C How to remove entire dash panel on BN6? Austin Healey 4
crispy How to Remove the Exhaust Manifold?? [late BJ8] Austin Healey 27
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
C MGB How do you remove "speed nuts"? MG 9
T TR4/4A Replacing rear pinion seal - remove driveshaft? Triumph 21
55modified Should I remove driver's side fender to work on footbox on my BN1? Austin Healey 14
R Remove engine/transmission advice needed Austin Healey 4
abarth69 Should I remove this section Spridgets 8
K TR2/3/3A What is best way to remove old nylon/rubber bush 525-020 from steering box shaft? Triumph 5
D TR2/3/3A wooodruff keys... how to remove Triumph 25
B remove BJ8 dash ? Austin Healey 1
Steve1970 TR6 Can I remove the shim on the rear gearbox mount [J-type OD] Triumph 11
4tecdog Access to remove Ariel Austin Healey 15
L Best Polish to remove surface scratches Austin Healey 12
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
C TR4/4A Best way to remove transmission fill port? Triumph 8
P How to remove the lever control? Austin Healey 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
D BJ 8 How to remove chrome trim strip from door tops Austin Healey 7
S TR2/3/3A remove protective covering off floor pans Triumph 6
bighealeysource Best way to remove dried polishing compound Austin Healey 10
AngliaGT Easiest Way to Remove/Replace Rear Axle Seals/Etc.? Spridgets 9
NutmegCT How to remove old weather stripping Restoration & Tools 8
J TR2/3/3A What is the best way to remove and replace carb shaft bushings. Triumph 4
Got_All_4 General TR How can I remove the finish on this center console for my 7 Triumph 9
B Remove Crank Nut Austin Healey 55
R Can't remove rear flexible brake hose Spridgets 5
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
S TR2/3/3A remove a clutch fork Triumph 1
maxwedge5281 remove 100-6 grill emblem Austin Healey 1
J TR2/3/3A Remove old dash vinyl. Triumph 2
drooartz MGB-GT Any gotchas when remove/replace rear axle? MG 4
Boggsy64 MGB Advice - Remove the seats MG 8
C How to remove temp sensor at block? Austin Healey 16
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
Lukens TR2/3/3A Before I remove my steering box... Triumph 10
