""""""starting to make loud tapping noises above 3k rpms"""""
is it half engine speed...? Could be a valve adjustment is in order...at least an inspection.
"""""Is this a sign of bearing trouble? """""
if it's metallic tapping, prolly not. Excesive bearing wear = low(er) oil pressure and really hammered/worn a whirring noise from the bottom of the motor on up rev and down rev.
"""""""just had the clutch replaced, and now there's a constant vibration that wasn't there before"""""
prolly an imbalance in the pressure plate. If they had the flywheel surfaced , could be got something bass ackwards on assembly. I wud suggest a trip back to the mekanik...."fix it" as the vibes werent there before.
""""""""I suppose at 113k miles, I should expect to be in for some heavy duty repairs. """"""
Cant drive em forever.....small displacement motor and back B.C. (before computers) when tractor motor and 50's designs prevailed, 113K is a lot of miles.
"""""""I've dome pretty much everything else, """"""""
like brain surgury? just kidding. /ubbthreads/images/graemlins/thirsty.gif a few pints of Watneys and an owners manual might be a start.
