How do I install Bugeye heat shield?
ichthos
The heat shield that came with my bugeye when I bought it was in pretty poor shape. I finally bought one from Ashley Hinton on Ebay. I am not sure where the heat shield bolts on the bottom hole - does this bolt to the breather tube bolt? Any help is greatly appreciated.
Kevin
jlaird
Is it a fuel pump bolt? I have never seen one like that. Looks like an orginal.
The_architect
Kevin, seems almost too obvious but have you shot Ashley Hinton an email with your question? Would love to know what they said.
Charlie
I
ichthos
I thought about that after I posted, Charlie. It takes a while to get a reply sometimes - just thought the forum would be faster. I will do that when I get home tonight.
I'm dead in the water until I get my gaskets from Moss anyway.
Kevin
Gerard
Kevin
I've emailed them before about buying their front plate plinth and <span style="font-style: italic"><span style="text-decoration: underline">never</span></span> received a reply.
TulsaFred Bugeye Windshield Install - no sweat Spridgets 11
J Bugeye seat back upholstery install Spridgets 9
longbridgehealey Victoria British Bugeye carpet install Spridgets 2
TulsaFred Bugeye wiper rack install/remove Spridgets 3
6 How to install Bugeye top? Spridgets 2
G Install Bugeye dash in my 67 Midget Spridgets 0
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
E Heater install Spridgets 2
algot1901 Roof install Other British Cars 16
A Spitfire Install fan Triumph 1
S Install drain cock in radiator. MG 2
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
6 Master Cylinder Install Spridgets 5
S MGB Transmission cross member re-install MG 14
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
K TR2/3/3A Brake caliper piston install? Triumph 18
EWD TR6 Top Install Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
R side light install Spridgets 2
R TR2/3/3A Install new wiring harness in steering column Triumph 16
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
J Tips for quarter elliiptic spring install Spridgets 3
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
EWD TR6 Trunion Install Triumph 0
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
66healey BJ8 shifter spring install Austin Healey 2
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
C How to install Stone Guards on driving lights? Austin Healey 7
F Heater valve/tap gasket- Install dry? Austin Healey 10
Csarneson BN4 Cam Gear Install Austin Healey 3
Rut 5 speed install Spridgets 14
R More Shroud to Scuttle install Austin Healey 4
R Dash Install questions Austin Healey 31
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
J TR2/3/3A Trunnion Install Triumph 3
B TR2/3/3A Cigarette Lighter Install Triumph 7
D Prepping to install engine Spridgets 2
P BN2 new wood steering wheel install Austin Healey 5
C MGB Paint first or install mechanics MG 10
T TR4/4A Rear Seatback/Hoodstick [Top] cover install Triumph 0
D BT7 Timing chain install Austin Healey 2
CessnaTPA Tonneau Install Question Austin Healey 13
