Gliderman8 said:Here's how I did mine...
TOC said:The way it's hooked up, rotating CW as you look at it, those straps will fold up into pretzels when you put a wrench on it....
TR3driver said:Lefty-loosey, righty-tighty
TOC said:Just like the local guy....spitfire.....used the starter, came right off......y'all are making this harder than it is.
Proper socket in a long breaker bar, lay end of the bar on top of left hand frame (viewed from driver's seat), neutral, crank it.
TOC said:Gliderman8 said:Here's how I did mine...
So.....what model is that? When did they come up with reverse rotation? The way it's hooked up, rotating CW as you look at it, those straps will fold up into pretzels when you put a wrench on it....
