jhorton3
Took Midgie on a 70 mile round trip in the blazing heat yesterday for Karen's company picnic. She did well (Midgie and Karen). Idle was even, didn't overheat, and with what seemed like 100 red lights and stop signs along the way the brakes and clutch did well.
The heat was unbearable though. I need to get some insulation put down and put more plugs or grommets in the firewall. Also would help considerably to put the pedal box cover back on. I'm definitely going to put some insulation down on the transmission tunnel, and thinking of putting it down on the floorboards. What do most of you use for insulation?
I think I snapped my speedometer cable. I've had trouble getting it up to 50-55 MPH, or so I believed. Yesterday in a straight away I was running 4,000 RPM in 4th gear. I'm running 155/80R/13's for tires. Speedometer showed 45...50...55...then 0. It never recovered. Checked to see that the cable was still attached to the gauge and the transmission. Discovered the cable had landed against the exhaust pipe. It burned away all the plastic cover down to the metal sheath. I suspect it got too hot and snapped.
Also having trouble with the back carb. The jet doesn't want to return back in the bushing and this happens most when I push the choke back in. I readjusted the linkage thinking it might be binding, but it's still happening. Also having to run that back carb richer than the front carb.
Still having a mechanical noise too. It's either an exhaust leak or the valves need to be adjusted again. I only notice it when I'm driving though. Figure this week I'll set about making sure nuts and bolts are torqued and tight, and recheck valve adjustments.
So far the PCV system is working well and the oil leak is just a couple of drops. A lot better than it was. I need to take the valve cover off to strip it and paint it so it looks more presentable.
