Help....I am so confused.
The problem: Horn doesn't work
Went to chek wiring. Started with online wiring diagram and Bentley book. Found that acording to both the horn relay has 4 wires, (purple, purple, purple/blk, and purp/yel). I locate the horn relay in the inner fender just a few inches toward the windscreen from the fuse box. Relay is marked LUCAS with leads marked C1, C2, W1, and W2. I am pretty sure my relay is bad.
Here is where it gets interesting.... TRF has a horn relay for about $59. I went online looking for a deal and found a "Overdrive relay" on Ebay that looks EXACTLY like my "horn relay" for $10.00. Checked out Rimmer Bros. and find another Overdrive relay that looks just like my "horn" relay.
Item 67 and 72 are the horn and overdrive relays respectively....THEY LOOK THE SAME TO ME! And they both look like what I need to replace.
The question: Is the horn relay indeed the small silverish relay marked LUCAS C1 etc. etc. with all of the purple wiring coming in and out?
Question 2: Did they (TR6) all come wired for OD whether they had OD or not? If not, what is the block below the horn relay without the 9 leads and many wires?
Sorry to be long winded but man am I confused. Not to mention cheap and i don't want to spend $59 when I only need $10.
