bugedd
So I hooked up my Hella horn a bit back, got it working okay. Then today I went to hit it to show off how stinkin loud it is, and nothing. We checked the relay, all is working well. We traced it back to the steering hub. When connecting the hub with a jumper to a good body ground, the horn sounds. When not jumpered, nothing. Best I can tell, the horn push grounds to the hub, which in turn grounds to the steering shaft. Somehow, this is not grounding to body, and this appears to be the issue. The steering shaft is not grounding to the column either, probably insulated by grease. So it seems I need to make a ground from steering shaft to body to make the horn work. Does this sounds right, and has anyone run into this also?
