AUSMHLY
What is the purpose of the small rubber buffers under the hood of a BJ8. Are they suppose to touch the hood when it is closed? Reason for asking is, I am trying to center the hood. Gap all around is good. Problem is the front corners of the hood are not high enough to be flush with the rest of the hood. Seems the adjustment is with the hood pin. By turning it, it raises or lowers the hood. When at the right setting, it seems the pin hold the hood, centers the hood and determins how high or low it is. Are the rubber buffers suppose to make contact? If I push down on the hood, then they will touch, but release pressure and they don't anymore. Seems the hood will be moving around a lot, only being held in place by the pin. (the two safety latches don't seem to be of any help in the front, were the problem is). So, is the pin job to hold the hood closed, center, align, including height?
