I have a Honda DelSol that overheats at idle.
Once it is moving, it cools down, so I assume the water pump is working
It has electric fans, one for the radiator and one for the condenser.
The condenser and radiator sit side-by-side.
Both fans are working
The tempeature sending unit is on the engine, not the radiator.
A blocked up radiator is a possibility. I had a 1984 Civic where that happened.
Although a radiator cost a lot more than a water pump, it would save me a lot of time if all I had to do was replace the radiator.
The car has an air bleed screw, near the thermostate housing, for the coolant system. I think if I open this bleed screw after the engine is running, water should really shoot out if the water pump is working.
Any thoughts?
Thanks
Ron
Any thoughts?
Thanks
Ron
Hi Guest!
