"Homemade" Watts Linkage
Tabcon
I'm using an alloy differential cover I bought from Racestorations on my rear end and I was just going to get the watts linkage assembly they sell also, but with the exchange rate the way it is, I decided I'd try my hand at making my own. I don't have a sophisticated garage set up (huge understatement) but I have a cheapo drill press I got at Lowes for Christmas as a gift to myself for being such a good boy. I ordered some high strenghth aluminum the nuts, bolts & bearings from McMaster-Carr and bought some taps and drill bits locally. After many long winded conversations with myself contianing a slew of expletives, I finally finished the linkage part. I still need to make the brackets though. I don't want to weld them to the frame though, so I'm working on some drawings for some bolt on type brackets.
By the time it's all said and done, I most likely could have just sprung for the Racestorations set up, but that would not have been as much "fun".
[img:center]
[/img] [img:left]
[/img]
Re: "Homemade" Watts Linkage
You do good work my friend! Purty.
Very Nice work. You make it look easy.
You did that with hand tools and a drill press?
I can't imagine what you'd be making if you had a mill and lathe !!!
Excellent work !
It amazes me the stuff they sell as "tools" now. It takes me 20 minutes to set up the drill press just to do what every decent one should do, drill straight.
It's almost as if you have to make tools to make the tools you buy just work somewhat decently. Why in my day...!
Very nicely done, what I more impressed with is you did this without a mill, good job !
What's a mill?
LOL
I really like working with alumiunum. I used 2024 high strength aluminum plate and solid hex bar I got from McMaster Carr. I couldn't find any counterbore drills for metal locally, so I used one I had for wood on the aluminum and it worked great. I just had to go slow.
Tab, a mill is next years Christmas present to yourself! Great job!
Tinkerman
Those little (Grizzly) mini-mills with CNC are supposed to be pretty nice to have for small projects. Of course, it really makes the parts cost a whole lot more when you figure in the cost of the equipment.
Beautiful hand work.
Tab,
Your pictures don't show up for me? What kind of image did you use?
Thanks,
BOBH
Tab,
super sweet! I can't believe you did that with just a drill press and hand tools. EXCELLENT !
Rob
I look back now with gratitude, and wish to express my heartfelt thanks to Mr. Watson, my high school shop teacher. Without his excellent instruction, my incredible fabrication skills of today would not have been possible. For it was Mr. Watson who not only taught me the importance of tucking in my shirt and always wearing protection, but also how to craft one darn fine chopping block.
