M
Member 10617
For what its worth... this posting is for new owners just getting to know their cars...
It can also be labeled "Even a blind pig sometimes finds an acorn."
I took a long ride yesterday over a steep Blue Ridge Mountain pass. After reaching the eastern side, I noticed that my engine (TR3A) was beginning to missfire. I thought perhaps that something might be clogging the fuel line and continued on trying to evaluate what was happening. The missing got worse, and I began to smell a bit of gasoline.
Deciding that I might have a fuel problem or an electrical problem, I stopped the car, checked various lines, and then checked my spark plug wires to make sure they were on securely. When I pushed #3 wire, I got an electrical shock. I concluded that it was arching and that the piston was not firing regularly or properly.
I headed home, over the mountain, nursing the car along at 30 mph. The missing seemed to get worse.
Fortunately, I got home without having to call AAA. The first thing I did was to remove the distributor cap and its wires and install a new cap and wires that I had on hand for such an occasion. Took the car for a test drive and it drove perfectly. No more missing.
So, if this happens to you, you might keep the spark plug wires in mind. Perhaps even carry a back up distributor cap and wires with you in your trunk.
Were it not for the shock I got when fiddling around with #3 wire, I probably wouldn't have found the problem so quickly. It was purely by accident...
Or... as they say around here, "Even a blind pig sometimes finds an acorn."
My apologies to experienced readers of this Forum for carrying on about what was clearly a very simple problem to analyse and solve..
