TR2/3/3A Hole in transmission bellhousing TR3!!!!
triherald
Well my started fell apart on my TR3, The nut on the end of the started ended up in the bellhouseing of the car. While driving the nut came loose, hit the flywheel and broke a hole about the size of a quarter in the bellhousing. Is there a fix for this.. I have though about building a rubber plug for this... I am guessing it could be welded??
Any other suggestions..
Jack /ubbthreads/images/graemlins/thirsty.gif
piman
Hello Jack,
it's up to you, it can be welded, but it really is not a problem just to leave it. There will be no trouble doing that.
Alec
bluemiata90
Save the money and use a plug. I'm sure the money you save will be used to fix or buy something else for the TR3. I would at least plug it thou. You don't want to get road dirt or water inside there.
Geo Hahn
Your profile says you have a 57 TR3 yet the nut you describe sounds like the one on the later style starter. A 57 would have come with the 'bullet nose' starter which has no nut out there.
Some folks use the later starter on the earlier cars but have to poke a hole in the bell-housing to make room for it (the later bell-housing has a bulge to accomodate the longer pinion assembly of the later starter)... suggesting that a hole in the bell-housing isn't necessarily a problem. A plug or other simple patch should work.
MDCanaday
Jack the hole is no problem, but if there are fractures in the metal surounding the hole they should be ground back to prevent spreading. My suggestion is to get a plastic body plug, dress the hole to size and glue it in. The reason to plug is that its too much of a temptation to mice if you leave it open.Not to say you have a ratty garage, but there is little chance that a mouse cant force his way into the best kept house. I recently got to remove the heater fan on a rover to exhume a mouse and her young who had all persished when the owner turned on her defrosters.
This was a 20 minute deal, pulling a tranny would not be.
MD(mad dog)
0 Open hole on Transmission Spridgets 9
M Mysterious hole in transmission Triumph 52
SpeedyG TR4/4A Hole in my firewall Triumph 12
apbos The next rabbit hole. Help ID the chassis. Racing 27
M 1500 Midget water pump weep hole Spridgets 2
B How big is the floor pan drain hole? Spridgets 0
B tachometer cable has a hole in it Restoration & Tools 7
JFS Wedge Stripped gearbox filler hole thread Triumph 3
Bocaray TR2/3/3A TR3 Antenna Hole Plug/Cover? Triumph 2
69MGC T-Series TC Oil Pan Weep Hole, Is it really necessary? MG 4
Joel Lester TR2/3/3A Oil hole size for Camshaft bearing Triumph 4
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
Walter74 Unknown Hole Purpose Austin Healey 2
T TR2/3/3A Clutch Pushrod hole location Triumph 4
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
D TR2/3/3A extra hole in my water pump? Triumph 3
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
CinneaghTR TR4/4A Hole at Bottom of Threaded Stud Hole in Block Triumph 6
S TR2/3/3A Drilling a 3/16 hole in fresh paint Triumph 1
L TR2/3/3A Purpose of the hole in a bracket Triumph 8
K Diameter of Washer Bottle Hole in Parcel Tray Austin Healey 4
S TR2/3/3A clutch pedal connection hole Triumph 9
P TR6 Rocker panel hole Triumph 16
R TR2/3/3A Pin Hole in gas tank Triumph 9
D TR2/3/3A Strange hole! Triumph 5
J TR2/3/3A Hole in Rear Hub Triumph 7
Jim_Stevens TR2/3/3A Antenna hole? Triumph 11
ckeithjordan TR2/3/3A Trim Hole Size Triumph 3
R TR6 Trunion Hole Triumph 2
T 100 4 Seat Base Fixing Hole Centers? Austin Healey 0
R TR2/3/3A Timing hole alignment Triumph 1
D TR4/4A water pump mystery hole Triumph 6
T TR6 What's this hole for? Triumph 5
wingsandwheels MGB new project...need like a hole in the head MG 8
S TR2/3/3A gas tank hole body work Triumph 7
T Grommet - sling hole in floor - XMSC108 Spridgets 3
R Plug bell housing/clutch housing hole? Austin Healey 10
Jim_Gruber What is this for, 3 holes + 1 Large hole on rear License Plate Indent on BE Spridgets 17
R water pump small hole does line up Austin Healey 7
Griz What is this hole for? Austin Healey 10
L What is this mounting hole for ? Spridgets 7
T TR2/3/3A Antenna Hole Blanking Plug/Fender Mirror Placement Triumph 6
cmacmillan TR6 75 TR6 Weep hole weeping.... Triumph 2
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
6TTR3A TR2/3/3A Complete firewall hole illustration Triumph 3
K TR2/3/3A Clutch Operating Shaft with bolt hole in wrong location? Triumph 3
Tinkerman TR2/3/3A Hole on top of my tranny tunnel Triumph 9
K TR2/3/3A Ovalled bush hole in lower A arm front suspension. Triumph 1
S hole for speedo cable Austin Healey 1
