Hmmm - no timing mark on the pulley. Now what?
tdskip
Seems I have a number of things that have gone missing on this car. Choke adjustment screws, matching needle sets, all sorts of stuff. And now I find the timing mark has gone bye-bye.
Get her to TDC and put some paint on the pulley as an approximation?
EDIT - Wait, the timing mark on the pulley is simply a small v-shaped notch, yes?
Platinum
White touch-up paint.
2091351
Liquid Paper in a bottle. :thumbsup:
dklawson
For the 1275... the timing marker tape kit from Advanced Distributors.
T
tdskip
Thanks guys - got paint on it. Now I just need a swivel head on my shoulders to actually see the darn mark under the call!
davester
That's what small children are for. :devilgrin:
T
tdskip
Ha! About time there was a productive use for them.
I'm at 20 degrees around 1k RPM, advance <span style="font-weight: bold">not</span> disconnected. Where do you guys like to run?
EDIT - it is 20 with the advanced blocked as well. She has a 1098 with a Jeff rebuild Distributor running a Pertronix system.
davester
Personally, I think it is best to set things up so that you're just under 35 degrees at maximum advance (say 3500 rpm) and let the idle setting fall where it may. The idle advance is not particularly important, but the max advance is. This will require adding more paint marks.
drooartz
That was Hap's advice to me with the motor he built for me. About 32 degrees at 3500 RPM or so, with the vacuum advance unhooked and plugged at both ends.
Also, you really want to move that timing pointer up to the top. Makes *all* the difference.
T Hmmm - not quite the same. What to do? Triumph 10
DNK HMMM Triumph 16
NutmegCT hmmm - is that car legally yours? Other Cars 10
weewillie Hmmm I wonder British Motor Corp 0
T Hmmm. here's an interesting offer. MG 2
T TR4/4A Hmmm, Cardboard Tunnel for Rad - 4A Triumph 12
PATR8 Wedge HMMM what I learned today about TR7/8 Triumph 12
TNMGB Hmmm...can't get key out of ignition... MG 11
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
M 1275 Timing Cover Vent Spridgets 2
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
K TR2/3/3A Timing chain rattle on start up? Triumph 2
D Cam Timing question. Spridgets 11
KVH General Tech Valve Timing--No Marks Triumph 20
drooartz MGB Question on timing and vacuum MG 11
E Ignition Timing Austin Healey 14
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
56HealeyDan 100-4 Timing and Vacuum Austin Healey 5
K TR2/3/3A Timing marks on pulley? Triumph 10
LAW75 Timing Chain Cover Gasket Austin Healey 12
Lin Ignition timing question Spridgets 2
Kolecki TR2/3/3A engine assembly cam timing issue Triumph 8
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
A Timing cover access Spridgets 6
BN6_2197 BN6 Static Timing Austin Healey 2
vette Timing Marks! Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
J TR6 73 TR6 Static Timing Questions Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR4/4A New valve gears/timing Triumph 21
K TR2/3/3A Ignition Timing? Triumph 11
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
M 100-4 Timing Pointer Austin Healey 5
D TR2/3/3A Timing chain tensioner. Triumph 3
KVH TR4/4A No Marks on Timing Gear Triumph 30
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
vette MGB 74 1/2 Timing Specs. MG 16
B Timing Light question Austin Healey 0
F TR6 Timing adjustment Triumph 13
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
D BT7 Timing Advance Austin Healey 17
D BT7 ignition timing Austin Healey 5
R TR2/3/3A Timing Triumph 3
F TR2/3/3A Ignition Timing - Again Triumph 11
