Hmm. Parking Lights
10musketeer
Replaced Ignition switch and all works great. Put steering column back in and now both rear running lights, both plate lights and the front left parking light is out. The hazard switch also only works 1/3 of the time. All other lights/blinkers work great and bulbs on all are good. I tried following the diagram, but am stumped. Any thoughts come to mind? /ubbthreads/images/graemlins/confused.gif
Could be a loose connection on the switch/es. Had a similar situation on my 1500,connections on ignition/flasher fell off. /ubbthreads/images/graemlins/rolleyes.gif
Stuart. /ubbthreads/images/graemlins/cheers.gif
Check the parking light fuses and/or rear harness leg at the glove box or far right side of the dash. Red wires with fuse holders are up there.
Flasher unit is behind the console, I'd suspect a dodgy connection in that thing.
Never mind what I said above. Edited.
Make sure the connector block just under the dash (left side behind turn signal stalk) is in tight. Something similar happened with me recently and I had a block that wouldn't sit right after I installed a new gauge and things got moved around.
