Highway Shutdown Need Advice
LakeJohn
My 1967 BJ8 ran perfectly for 2000 plus miles in 2007. This week, May 6, The car ran strong for 45 miles of highway driving and then lost power and stopped. I got it restarted but the problem immediately reoccurred withing two miles. To the untrained eye, the problem seems like fuel starvation.
I know that the floats are working and the banjo filters are clean from an inspection in early April. The fuel tank is new in 2007 as well as the fuel pump (non-standard NAPA). The car also has an inline fuel filter - new in 2007 after tank replacement.
What am I missing for an adjustment on the roadside? I know that the fuel pump is active from hearing it before starting the engine. My only current option is towing from a convenience store where the car is now sitting.
Jack White
Randy Harris
I had the same issue a number of years ago. Here's what my problem was: An obstruction in the fuel tank. As the car proceeds the obstruction (in my case a metal washer had fallen into the tank from a Monza style gas cap that fell apart)is sucked up into the fuel line/gas tank strainer from the tank. This of course starves the carbs and the car dies. At this point the obstruction naturally falls back down into the bottom of the tank until the next time you hit the road. For me this went on for months until I finally had enough and had the tank cleaned out and found the culpret.
Randy '66 BJ8
ArtQ
Depending what you mean by "lost power", the other option is an electrical problem. I recently had a problem that sounds similiar. After driving for awhile, the car would stall and though I could get it running again, I could not get any real speed or throttle response. After changing or checking all the usual villains( coil, points, condenser, distributer, spark plug wires, etc), we found that the high voltage wire from the coil to the distributer cap had been burned at one end.
AH100M
Don't neglect the battery cut-off switch in the boot. The white wire shorts out the ignition coil when the switch is in the "OFF" position. My switch failed such that it shorted the coil in the "ON" position as well. Went to pick up a pizza, started to drive home, car died. Drove me nuts for about 10 min. until I found I had no spark from the coil. Replaced the coil, still nothing. Checked point gap - fine. Then I ripped off the friggin' second white wire from the coil and everything worked fine. Always carry a spare coil, points, condensor, spark plug, cap, ignition wire, fuel pump, carb. needle, piston, head, gearbox, ...
AUSMHLY
"Always carry a spare coil, points, condensor, spark plug, cap, ignition wire, fuel pump, carb. needle, piston, head, gearbox, ..."
I like the way you think AH100M!
Dave Russell
Yoda - R.I.P
You are starting to think like Dale of Triumph fame.
After all - The cars really need 200 to 300 pounds of extra ballast in the back & you can't be too prepared. Don't forget lots of tools.
Patrick67BJ8
This same problem happened to me. After several attemps to fix it and finally figuring I had it fixed I took it out of town on the highway. It car died after about an hour on the open road.
Culprit was dirt in the sump of the fuel tank.
BTW: Look up a thread about this same problem. I "won" the troubleshooting award(whatever that is) because I figured out the problem another owner was having.
The fuel lines also have junk in them after years of use and it appears that it doesn't take too much restriction before the fuel pump decides it can't handle the pressure and dies. It usually does come back up after it cools down.
Several years later I had a restriction at the top of the fuel line under the jump seats and that one ended up being totally blocked and a section of the fuel line had to be cut out.
nevets
had similar problem, turned out to be loose (adjusting) screw that secures the points to distributer plate.
Johnny
I might add ROTOR to your lists. BTW just bought the new premium rotor from Moss, worked great!!! I seemed to have a "miss" at times and sluggish idle too. Replaced the rotor with the new one and VAVOOM!
HEALEYJAG
If the fuel pump is "racing" and never stops.....vapor lock.....
My V-12 Jag would do this when I accidently put gas with and alchohol additive.
AngliaGT A Few More along Highway 220 Spotted 3
T Adjusting windows/tops etc. for comfortable highway travel Austin Healey 10
B Highway overheat Austin Healey 40
S Highway Driving Spridgets 22
C '72 Midget Runs On 2 Cylinders at Highway Speeds Spridgets 73
K TR2/3/3A TR3 Diff Ratio for Highway Driving ? Triumph 5
JPSmit Last night was driving on the highway Spridgets 1
MadRiver TR5/TR250 TR250 Highway Speeds Triumph 3
jhorton3 Highway Mileage Spridgets 8
Steve1970 is a little vibration ok on the highway? Triumph 16
ChrisS 36'F, no top, highway driving Spridgets 12
JPSmit spotted on the highway. Other Cars 2
Creatrixx Engine Missing at only Highway Speeds... British Motor Corp 8
W Bugeye on the Pacific Coast Highway Spridgets 10
T Midget body shell for sale - Ortega Highway SoCal Spridgets 0
P Overheating at highway speeds Triumph 20
Alan_Myers TR4/4A Highway Robbery??? [TR4 Trunnion Bushings] Triumph 5
B speedo needle bounce at highway speeds MG 3
T TR2/3/3A rough running after 20 min shutdown Triumph 9
P Starter problem after extended shutdown Austin Healey 5
N Cold Plug site shutdown! Other British Cars 19
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
HerronScott Favorite Craigslist search tool shutdown Triumph 10
Luke_Healey Causes of dieseling on shutdown? Spridgets 21
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
