TR2/3/3A High Oil pressure
Simmo
I have had a few TR3a's and they have all behaved the same with oil pressure. i.e. around 70 to 80 psi at normal driving.
I just bought another one which has had a major rebuild some 2,000 miles back.
At start the oil pressure is 100psi which I consider to be too much.
After driving about 5 miles and engine hot it drops to the normal 70-80 psi.
Brand new electric Smiths gauge but also showed the same on the old Jaeger gauge.
20W -50 Penrite, new oil and new filter.
This 100 PSI reading seems wrong. Can anyone offer suggestions?
TR3driver
Great Pumpkin - R.I.P
Use thinner oil until it gets broken in better. 10W40 or 15W40.
TR3driver
Under what conditions? If you can't make 70-75 psi running at 60 mph with the oil hot, I'd say there is a problem. (Check the gauge first, they often lose accuracy as they age.)
But 50 psi at hot idle would be excellent with that kind of mileage.
CJD
The oil pressure regulator should maintain the approx. 75 psi through a wide range of oil viscosities and over a long engine life. The 2 exceptions are that oil is too thick at cold start-up for the regulator to reduce the pressure, and once you have a certain amount of excessive wear the pump does not put out enough volume to maintain the 75psi any more.
In short, if your pressure drops below 75 psi in a warm engine at speed, and 20w50 oil and adjusting the regulator pressure will not bring it back up...then it's time to start planning on a rebuild. Not to say the engine won't run many more thousands of miles after being worn out. I had an old Ford pick-up that would only hold 2psi at idle and 25 on the highway...and I drove it 10 years that way.
poolboy
I don't know if or why a TRiumph engine would be an exception, but Smokey Yunick* proclaimed that 10 psi/1000 rpms was all that was needed.
*You might have to 'google'.
TR3driver
That's a good rule of thumb, but doesn't always apply. In racing, where every 0.1 hp is important, you don't want to waste any power in developing oil pressure.
Probably is "enough" for the TRactor motor; but the design was created to provide a comfortable margin of safety above that. I'm not saying 50 psi at speed is reason to pull over and call for a flatbed; but it does indicate that something is not "working as designed". Unless of course, you've deliberately modified your engine to run low oil pressure, ala Smokey Yunick.
Besides which, 50 psi IS 10 psi per thousand rpm, at 5000 rpm redline.
Back in high school, I had a summer job hauling fertilizer. One of the trucks we used would turn on the idiot light at cold idle; when it got hot enough the light would be on even driving down the highway. It ran for a long time that way (longer than I had the job), but a friend of mine told me it eventually threw a rod.
busybrit
The correct oil pressure is 40 - 60 lbs/sq" in top gear at speeds 30 - 40 mph. Once the oil is hot use the oil pressure regulator to adjust. From page 48 of the Service Instuction Manual for a TR2.
I was told that high oil pressure can "wash" the bearing face of some types of bearings. FYI the contact bearing face on new Tri-Metal bearings, known as the overlay can be less than .001".
TR3driver
Lotta things changed between the time that manual was written, and the TR3A was introduced; including power output and even oil filter type. TR2 and early TR3 used a bypass oil filter rather than full flow as on the later cars.
So anytime the later manuals disagree, I tend to believe them over the workshop manual.
"Practical Hints for the Maintenance of the Triumph T.R.3." says on page 8:
"The gauge should read 70 lb./sq. in. minimum when the car is travelling at normal speeds and the oil is hot."
CJD
Smokey raced Chevy’s. Triumph raised the TR pressures, obviously for durability reasons.
sp53
Am I correct to assume that the oil pressure regulator valve only turns down oil pressure and does not raise the oil pressure any? (Unless out of adjustment) So, is the regulator mostly in line to help on cold motors in cool climates, so there is not too much oil pressure on early start ups that could blow out gaskets, or do I have this wrong?
steve
G High Oil Pressure Austin Healey 2
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
D TR5/TR250 High oil pressure Triumph 5
B TR6 TR6 High Oil Pressure Triumph 20
A New to site. High Oil Pressure Austin Healey 18
SMGoose High oil pressure and this puddle... Triumph 77
6 100M high oil pressure Austin Healey 7
Lynn Kirkpatrick MGB MGB High Oil Pressure MG 6
Dadandson New Motor Start up with Xtremely High oil pressure Spridgets 5
newmexTR3 TR2/3/3A Oil pressure running high - TR3 Triumph 6
M Oil Gauge reading high pressure MG 3
J Oil Pressure Too High Spridgets 3
Ed_K Can oil pressure too high damage something ? Austin Healey 4
M BJ8 oil pressure too high? Austin Healey 1
C 100-4 High Oil Pressure Austin Healey 3
Andy Blackley High Oil Pressure: Too much of a good thing? Triumph 11
J Oil Pressure Too High? Austin Healey 2
Slider748 TR6 High oil pressure in TR6 Triumph 17
re26 HIGH OIL PRESSURE? MG 3
F Oil leak? High Idle? Spridgets 13
O High ZDDP oil Austin Healey 0
jerrybny High milage Oil opinions Triumph 5
Carlbanan56 MGB High beam problems MG 2
Carlbanan56 MGB High rpm problem MG 27
P TR2/3/3A British High Torque starter Triumph 6
MikeAH100M High Temp Engine Miss Austin Healey 2
Carlbanan56 MGB High resistance MG 2
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
S TR2/3/3A floundering At High RPM Triumph 29
M High-Torque Starter Austin Healey 10
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
LAW75 High-Pitched Noise Austin Healey 13
Hamish Racing General Tech Petrol/Gas with high ethanol Triumph 3
Taftster MGB Electric Gauges Read High, Any guesses? MG 5
B High-Torque Starter Rattling Noise Austin Healey 3
M 1275 too high? Spridgets 2
dougie Targa High Country 2021 Austin Healey 2
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
J Experience with High Ratio Steering Box? Austin Healey 15
R Speedo High Beam Warning Light Color Austin Healey 14
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY 64 front end too high Austin Healey 14
steveg High altitude mixture observations Austin Healey 4
R General Tech High altitude adjustments Triumph 3
R High Altitude adjustments Austin Healey 3
B TR6 1970 High Back Seats for TR6 - Side bolste wires squabs neededr Triumph 3
bfitz TR6 72 TR6 clutch high engagement point Triumph 16
A MGA High beam indicator light not working MG 2
