Andy Blackley
Today I replaced my crank thrust washers with Scott Helms nifty replacement, and since an oil change was in order I also took the opportunity to replace the stock oil filter with a spin-on adapter and a Bosch filter. I put in Castrol 20/50 "High Mileage" started her up and checked for leaks. Seeing none I took it out for a spin. The cold oil pressure was pegged at 100 psi, which it usually does on start up. Typically within a few minutes the gauge would read high, but not be pegged out. Previously the oil pressure would drop as engine temps increased so that after 20 min or so it would be a 70 on a cool day at 2000 rpm and 60 on a 90 degree day. Stinking hot it never goes below 30 psi. Satisfactory oil pressure.
Now tonight driving around the gauge would peg at anything above 1000 rpms for the first ten minutes, and dropped to 90 psi when fully warmed. Hot idle pressure is around 45 psi. On acceleration it pegs again, which tends to spoil the fun.
The high reading makes me worry. I suspect the filter element is too small/restrictive. The oil preesure relief valve had been replaced a few months back and before the conversion the oil pressure was great as described.
Anyone have a thought or similar experience?
Thanks!
Andy
Thanks!
Andy
