[ QUOTE ]
Are the ratings/formulations/blends/additives in the US different from ours in NZ, and those available in the UK when the manuals were printed?
[/ QUOTE ]
A quote from the above reference:
https://www.ethanolrfa.org/objects/pdf/DAI960501classic_car.pdf
"There are two test methods, the Research Method which yields a Research Octane Number (RON) and a Motor Method which yields a Motor Octane Number (MON). The number posted on the gasoline pump is an average of those two numbers, (R+M)/2.
Today, gasoline octanes range for 85 to 94 (R+M)/2 with the typical grades being regular unleaded at 87, midgrade at 89, and premium at 91 to 94. Prior to the eighties, gasoline octane was often posted based solely on the Research Octane Number which allowed postings as high as 100 octane. Premium gasolines sold today often have a research octane number of 100 or higher but must post the (R+M)/2 value. For instance, a 93 octane premium will likely have a motor octane of 85 and a research octane of 101 (101 + 85)/2 = 93.
USA uses the (R+M)/2 rating system. As it says, prior to the 1980's USA used the "research" rating. Today, many European countries & some others still use the research rating method. Bigger numbers for the same equivalent octane rating. AV gas uses yet another different rating system.
Approximate equivalent ratings:
USA = 87 -- Euro = 91 -- RON = 91 -- MON = 82.5 -- R+M/2 = 87
USA = 89 -- Euro = 95 -- RON = 95 -- MON = 83 ---- R+M/2 = 89
USA = 93 -- Euro = 98 -- RON = 98 -- MON = 88 ---- R+M/2 = 93
USA producers are allowed some variation between their posted pump octane ratings & the actuals. Each batch of fuel may be slightly different & you may find that one brands actual octane ratings variy a bit from day to day. The "must have gotten a bad batch syndrome". In the end, it's a matter of what you are most satisfied with. For most modern cars with adaptive timing controls, few folks will notice much difference between 87 & 93 octane. Older cars excepted, of course.
Additionally, there are seasonal variations in the volatility (how easily the fuel is vaporized) from region to region. This can lead to a more volatile winter blend causing vapor lock on an unusually hot spring day.
