regularman
I had this problem years ago when I drove the car. I bought one of those clear glass filters that you can take apart and clean out. I put it right before the pump. You can just look under there and see how bad it is.Brian_C said:I'm inclined to think it's a tank/filter issue, too. I had the same problem. The car would run great around town, but as soon as I tried to push it to 55+ the filter would get completely clogged. I had a ton of sediment at the bottom of my tank. New tank + new filter = no more problems. If you have the old filter, blow some carb cleaner through it and see what comes out.
If it's the tank, then the filters will just continue to get clogged (at the worst times, I'll add). My second filter lasted all of ~40 minutes of drive-time before it got stopped up.
B
