jvandyke
my Weber 32/36 equipped 1098 will sometimes behave like it's fuel starved when under load (cruising in 3rd/4th then accelerating).
I thought it was fuel pump so switched them out (electrics, ditched an SU for a Carter) it had no effect, so I replaced the filter right before the carb and it seemed to take care of it. Now it's back, so either;
a) there's crud in the fuel system plugging up my filter so that it can't keep the bowl fuel under high demand
b)the pump system itself can't cut it (both pumps were/are mounted in engine bay, I know I should move it back by the tank)
c) I'm on the wrong track and it's ignition related.
The solution is simply lay off the gas and wait or tickle the pedal, it seems to "catch up with itself" and I'm off again.
I can accelerate to redline in 1st or 2nd no problem but in 3rd or 4th it will induce the stuttering.
Thought I'd ask so I don't waste too much time fixing the wrong thing. Not too fond of running out of gas at high load, high rpm, could detonate, no?
