To summarize, the Tunebug started fairly suddenly to have a high idle, around 2000 - 2200ish. Suggestions came from the forum to check the throttle cables and such to see if it was binding. Here's what I did:
1. Made sure there was oil in the dampers, each took a little.
2. Removed the throttle cable and choke cable completely. Throttle cable will be replaced, but it did not seem to be bound up anywhere.
3. With cables clear, I applied a bit of choke with 2 fingers, throttle with 2 more, and reached across the engine bay and pulled the starter. I love cable starters! Car started up fine, and still ran fast.
4. Blipped the throttle, lifted the levers that get pulled by the choke, raised each piston a bit.
Car still idles fast. Lifting a damper piston makes the car stumble and run slow. lifting the little levers that the choke pulls lowered the RPM.
What do I test next?
