Martin Secrest
What could cause such a thing in my '72? I've got 150psi in cylinders 2-6, but 180 in cylinder 1. I've checked it cold and hot, throttle open, etc. My local LBC mechanic suspects bad oil ring in #1.
...when you do a compression test, remove the plugs, remove the ignition coil center wire, block the throttle wide open (push the gas pedal to the floor), and use the starter to turn the crank the same number of times for each cylinder... Probably something else, but my brain has turned to jello again...
Have the gearbox in neutral. Ever run over your own right foot?
Plug was sooty but not oily. Oil squirt did not change compression. When I went to pull the plug lead just now, the lead's interior contact came out with the plug. I might have been loose all this time, and that could have caused a soot buildup I imagine.
