TR2/3/3A High beams seem to be stuck on when the headlights are turned on?
karls59tr
Bronze
Pressing the floor button to lower the high beams dosn't work. Is it a failure of the switch itself or is there a procedure to track down a wiring problem?
Had it been working previously? did you do anything with the wiring?
If the answers are yes and no, respectively, it pretty much has to be the dip switch.
