Deleted member 7471
On my TR4-A, when the headlamps are turned on, the High Beam indicator lamp is on always, regardless of the position of the dimmer switch. When the headlights are on low beam the indicator glows a little bit dim. When the switch is made to high beam, the indicator glows somewhat brighter. I haven't checked, but I assume both elements in the headlamps are always on also.
My guess is that there is a short somewhere in the harness where the dimmer switch supply wire (Blue) is making contact with the high beam indicator wire (Blue/White). I checked the operation of the dimmer switch with a VOM, and it seems to be working correctly.
Am I on the right track here or is there something I have overlooked?
Thanks for any opinions.
Glenn
Glenn
Hi Guest!
