bill_powell
I need to tap your brains again!
Here is my HIF:
Smelled fuel last night on the way home. Today, I found fuel escaping here:
It's a pretty good trickle running along the 'plunger' and spring.I also noticed fuel escaping (from the far end) of my vent/overflow line, which is just below. I do have a fuel pressure regulator. Could the regulator have gone south, or should I be looking at a carb issue?
Thanks...
EDIT: Checked the regulator; no issues, running about 2 2/3 LBS, which is where I set it.
Here is my HIF:
Thanks...
Hi Guest!
