Re: HIF Throttle Disc - DOC
Paul, some of the HIF4 don't have the idle enrichement tube sticking up in the carb body, some are flush with the carb body and the early HS4 solid butterfly will work in them fine with no mods, just finished a set I did that to a week or so ago. Now if you have the carbs where the idle enrichment tubes sticks up, you can do one of two things, you can get the early HS4 solid butterfly and make the notch in it, or you can make the idle enrichement tube flush with the carb body like in the other HIF4s, I prefer the later of the two.
