I've just rebuilt my HIF 4 carbs AUD 550 for my 1973 MGB. The incentive for this project was really bad performance.
On the throttle butterfly valve there is a relief valve of some sort. On mine they were soldered closed!
Can anyone tell me what these relief valves are for and why anyone would solder them closed?
Since I put them back together I can't get the engine to idle at less that about 1200 RPM. I suspect that the relief valves are leaking and that may be why they had been soldered closed.
The back carb also seems to be drawing much stronger than the front carb. I intend to remove the butterfly valves and resolder the relief valves in hopes of plugging the air leak.
Any info/speculation would be appreciated.
