Hello all!
I just picked up a '76 Midget a couple of weeks ago, so I thought it high time to find a forum of British-car-knowledgeable people to help learn the ropes of these cars. I've heard all kinds of things, good and bad, but when I came across this Midget, I figured I'd give it a try.
I'm excited about everything about the car except its engine speeds in the 60-80 mph range (I'm going to be using it as my driver, and though I'm not on the highway often, it doesn't seem as though the Midge will be happy there). I got it from some friends of the family, who went through the trouble to have the engine freshly rebuilt with headers and a Weber DGV carburetor. No air pump, no EGR, no catalytic converter... just PCV. It had been on the road about 2 weeks after dropping the engine in (less than 500 miles) when someone clipped it in the rear. Then it sat for 6 years (!). It can drive, but it is wounded. I have a parts car in quite good shape, either to swap the drivetrain into or to supply donor body panels if I opt to repair the damaged car. Since I've had it, I've just been trying to familiarize myself with it inside and out and to get it tuned up as best I can. It had been in a garage while it sat, and the cylinder walls were clean... I squirted some oil in the cylinders, drained the ancient fuel (gas tank was clean), changed the engine oil, hooked up a new battery, and after some priming with starting fluid to save the battery some effort, it fired right up. As soon as I bled some response out of the brakes (they were pretty much empty), I took it for a brief test drive. FUN!!
There's a lot I don't know, though, and I'm not really pleased with the way the motor is running. It's the 1500 engine, and the emissions label says timing should be set at 2 degrees ATDC; my timing light says that at around 900rpm, it fluctuates between 8 and 10 BEFORE top dead center. The idle is somewhat erratic, varying about 200-300 rpm. Looking down the barrels of the carburetor as the engine runs, the primary looks normal but the secondary will sometimes dribble out a little non-atomized fuel. This increases if the throttle is opened at all. I have premium 93 octane fuel with some lead additive, as this car never had a catalytic converter. Starting with the engine cold, I set the choke fully shut with a light tension and the fast idle screw resting on the cam in the position it was when I got it. Upon starting the engine, it tried to race, so I shut it off, turned the screw out a good deal, and tried again. I set the fast idle around 1600, with the choke partially open. When it opened up more, at a certain point, it began turning close to 2000 rpm. I turned the screw until I had it back down around 1600, although it would sometimes jump a little higher or drop lower. At this point the choke was open, and I opened the throttle just enough to release the fast idle cam. Now it was running at 900 rpm, the desired idle speed, but it was struggling, and very nearly cut out once or twice. I turned it off and disconnected the vacuum advance and plugged the hose. Timing averaged 8 degrees before top dead center. The vacuum pull at the hose was very weak; I even unplugged it and the motor didn't really run any worse. Upon starting the motor again, with the advance hooked up this time, it idled around 1200. I turned the idle screws out until the no longer contacted their cams, and made sure the accelerator cable wasn't stuck, but the engine wouldn't go below 1200 rpm. Timing with vac. advance hooked up at around 1200 rpm was in the 14 degree ballpark.
The only other symptom that is unusual comes around 3200 rpm while driving; I didn't permit the engine to go much higher than that. It was a sound akin to a rattle, but it felt more like the engine being a little off beat or something. I'm really not sure what it was all about.
I'm suspecting vacuum leakage somewhere at this point. Does anyone know how this engine should be timed, or what might be off with it? I think I heard the previous owner mention a non-stock camshaft, but I'm not sure about that. Not sure if it would affect timing. I appreciate any help you can give me, and I'm glad to be aboard! Thanks!
Hi Guest!
