Can you help this guy out? He is on another forum and can't seem to get the answer he needs. Could you reply?
Following is a copy of his question
Thanks!
John
Hello,
I'm trying to locate an original OD switch bezel for a 1966 B, which goes between the bent-toggle-type switch and the dash. I have one from Moss, which appears to be aluminum, with "OVERDRIVE" and "NORMAL" painted on. In my memory (admittedly, dimming more each day), the original type was chrome with the NORMAL and OVERDRIVE engraved into the surface and filled with paint.
Does anyone know (or remember) what the original bezel looked like?
Thanks!
John
Hello,
Hi Guest!
