Deleted member 8987
See? Ask the questions, get the answers! Dial Indicator for TDC is good...if you didn't just look for the null. You want to mark the damper at a specific number before, like .010", or ,100", then match it on the after, mark the damper, and measure the exact point between those marks.
Stethoscope? Find a piece of rubber fuel line, several feet long, hold one end CLOSE to your ear (never touch it in case you hit that vacuum leak and suck your brains out. Engine running, position the open end of the hose near what you want to listen to. You will hear it.
Some you will have to learn is not a leak, rather the noise the air molecules make as the rapidly pass a specific point (joke).
Inlet gasket leak.
Carb base gasket leak.
Have Phenolic spacers? Leaks?
Have a brake servo booster?
Have a vacuum reservoir can?
Inlet valve guides?
Oh, and look at the pistons as you start to bring the throttle up to see if they all come up together....or if you have a single point failure.
Inlet gasket leak.
Inlet valve guides?
