They are still in business but they can take a few days to get back to you. Tony will usually be the one to get back in touch with you.Dom said:My Austin Healey needs a new top. I have tried to reach Heritage Upholstery & Trim by phone and email but get no response. Does any one know if they are still in business and if so what the best contact number is for them?
Dom said:Thanks! I have been trying to connect Heritage over a two week period. Their response time is not acceptable. I will look into a Robbins top which others have said is very good.
Just realized that the jute backing supplied by Heritage Upholstery and Trim does not correlate to Gary Anderson & Roger Moment's restoration guide. The guide indicated that the black side is suppose to be facing down (against the tunnel), and the brown side is glued to the back of the carpeting. This wouldn't have been a problem had they not cut the openings for the gear selector - which matters on a sideshift car. Turning it over, moves the opening to the right side.
I contacted Heritage to get their feedback and spoke with a guy named Bart. He indicated that their "expert" on Healey's had 20 years experience working on them and that Roger's book was incorrect and that it wasn't unusual to be incorrect. I also saw Rich's carpet installation guide and Rich was in agreement with Gary and Roger. It's laughable that someone in this field claims 20 (recent) years as their reason for their knowledge. I know Rich is no longer with us, but I put his history up against anyone at Heritage. Rich spoke highly about Heritage back in the day, which was why I used them.
Curious of others' thoughts on this - what's correct, and why does the exposed side color matter?
I know most here aren't as anal, but I spent a lot on this kit to be correct (which it is according to Bart). I guess I will install it as it was cut, but I would have thought Heritage would put more stock in the original restorer's notes. It will be one of those things that will bug me whenever I pull the carpet back to check the oil.
A couple of the hardest and most difficult pieces to do in BJ8 is the rear squab/fold-down shelf and also the seats. Most vinyl is thicker than the original stuff and you'll get into problems trying to use the thicker vinyl. It's very easy to spend $9k plus for a BJ8 Interior but if it's done correctly your car will reflect it the resale price should you ever want to sell it.A couple of years ago we got a quote from them (which took a while) and it was close to 5 figures for a complete interior for our BJ8. While their web site shows beautiful work which some have praised, I cannot justify that total. Also some of the other kits offered by the various reputable vendors are not that cheap either, and you still have to install them.
So I bought an old heavy duty Singer walking foot sewing machine, leather hides, vinyl, etc. and hopefully can do a respectable interior for a 1/10 of the quote. We will see.
jjs64bj8
A couple of thoughts for Interior info. There's 3 types of rear side panels with the first being for the Phase 1 cars. The Phase 2 cars have the early version with shoulder harness and the later phase 2 cars have the single large hole for the rear seat belts. Note: The black plastic caps for the rear seat belt hole covers are I believe the same for the MGC's. No matter which Panel you need the square grid lines on the side panels are the same for both vinyl and leather interiors. The reason I mention those grid line pattern is Heritage sent me plain smooth panels and we got into an argument about them. As it so happens I was right and the Concours folks backed me up as well as the Parts Manual. However, my wife is an Interior Designer and she said that the smooth panels work better with the smooth door and foot kick panels and the patterned rear panels would look outta place. I believe she's 100% correct on that. The first set of rear side Panels I received had to be sent back to be redone because the wood that was used was so stiff and would not bend properly and the metal front edge was bulging. The second set was done right but the foam was still thicker than the original.Patrick6jBJ8 is 200% correct in that the rear squab/fold down shelf is infinitely more difficult to redo that it initially appears. I have done several other (non Healeys) interiors in the past and this squab was a real challenge. I spent several weeks trying to get it reasonable using leather and vinyl looking at photos on line. If I had the $9K I would indeed probably go after the best, but the car is not going to be concurs and the money helps in other ways. So a less that perfect but presentable result is okay with me.
Attracted are a couple of photos as we start to assemble the interior. The squab is done and the seats are next.
Thanks
jjs64bj8
