I'm replacing the fuel line on my Herald. I've done the tank to the pump and now working on the line from the pump to the carburetors (it has 2 HS4 SU carbs). I know that there were several routings on the Spits but I think the HS4 set up was basically the same as mine. The pipe goes from the pump along the left side of the engine, behind the distributor and generator and around the front to the forward carburetor.
I think this is correct but it appears that someone added a plastic in line filter and perhaps moved the pipe forward of the thermostat housing. It looks to me like it might be better to run it behind the housing and forward of the rocker cover and put the filter somewhere else.
Anyone know?
Sorry no picture as I've removed the line already.
Tom
Anyone know?
Tom
