I posted on another thread that I would comment on the new carpets I'd ordered from Newton's and since I's been a while I thought I'd begin anew.
Really nothing extraordinary about the very nice quality carpets, I'm generally pleased but quite pricey. Might be good to wait for a sale from Moss or one of the others although I haven't seen their carpets so can't really compare. PM with questions.
Since I had removed the gas pedal with the installation, I decided to replace the jury rigged Spitfire accelerator cable that I had installed last year with the proper one from Rimmer Brothers. What I didn't count on was that it appears as though the part number is correct, the hardware on the carbs may not be. The cable does not match the terminal sleeve on the carbs and the angle is off even if it did fit. In short it is stickier than ever.
Here is a picture I found on line. I don't know if if this is the correct setup but it sure looks better than mine. I was unable to find that bracket setup on line. I could fabricate something but it would be awfully nice to just buy the correct setup.
Here is mine:
Finally, the pedal termination seems to just drop down from the top of the firewall with no support anywhere near the pedal, Does that seem right?
Here is mine:
