Replaced rotor. no change. Pulled a spark plug wire. No spark when engine cranks. Guess I'm down to the pertronix or the coil. Any test for the coil or should I swap out the pertonix as I have a spare? Tnx, Eric
Remove the dizzy and shake it. If the screws don't fall out then take the two screws holding the plate on and go in that way. If they fell in, they should fall out.Thanks Johnny. Coil checks out OK. Pulled on the 2 black wires, one had a solid white stripe. One wire broken. Don't know how that happened. In putting the pertronix back, 2 little screws fell down the dizzy. Am I screwed literally?
Not sure of everything you didm but now it sounds like the Dizzy is 180 out.The saga continues. Soldered the connection and covered with shrink tubing, closed up the dizzy. Upon starting I get two mammoth backfires and then stops. I admit to having perhaps foolishly adding some dashpot oil to each of the 3 carbs but actually none is visible in the carb shafts but I did get more resistance when closing them up. Any suggestions? Thanks, Eric
I would check the sequence of the plug wires just in case they were removed. I think the order: 1 3 4 2. Look for #1 TDC and go from there.Thanks Steve. Latest is: removed dizzy, cleaned it out. Replaced the pertronix with a new one. Replaced both the rotor and distributor with new ones. Checked gas line. Getting fuel, battery on full charge. Tried to start and the car, turned over very sluggishly, no backfire. Now getting spark. Rotated the dizzy both directions, no change. With the dizzy off the rotor turns normally and car cranks normally. Thought I had the dizzy in backwards. Turned it round 180 degrees, car turned over as normal but constant backire. Thinking now is, I had the dizzy in right all along. Will turn it round again. Perhaps try your idea of installing points and condenser. After 4 hours, went to bed. Very frustrating.
Regards,
Eric
